Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > NY / NJ / CT
NY / NJ / CT
NY NJ CT
Old 01-07-2013, 06:37 PM   #1
secono330ci
My Ride: 04' 330ci/15' A3 TDI
FS rear seat delete coupe/m3 $150
I have 10 sets of rear seat deletes that will fit any e46 coupe or m3 coupe. They are wrapped in black felt and will match the oem black carpet perfectly. This mod saves a good 50lbs and looks really nice.
Here's what it looks like on my car. The only difference is the top part of mine is wrapped in red suede.
Asking $150
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 01-08-2013, 12:11 AM   #2
rcsummers
My Ride: M3
Bump for a great guy!
"RICH"
My Build Thread
EURO.TECHNIKS
- Status Gruppe Tuning - Broadway Static - Recaro - DTM Fiberwerkz - AutoCouture Motoring -
Instagram: @summers_e46_m3
Twitter: @rcsummers0506
Xbox One: MisterMeisterM3
rcsummers is offline   Reply With Quote
Old 01-08-2013, 03:03 PM   #3
serdar255
My Ride: '01 325ci / '90 325i
Nice! Bump
For coding, custom shift knobs, and vinyl stickers: PM me
serdar255 is offline   Reply With Quote
Old 01-08-2013, 05:07 PM   #4
tks
My Ride: slower than yours
Does this make the car noisier?
Your car looks really nice, like the flow.
WTB:: Natural Brown Sedan Full Interior
tks is offline   Reply With Quote
Old 01-08-2013, 05:08 PM   #5
Gheybe
Gheybe's Avatar
My Ride: F80 M3
Bump. OP puts out.
Gheybe is offline   Reply With Quote
Old 01-08-2013, 05:33 PM   #6
rcsummers
My Ride: M3
Yes. because the seats act as insulation. The rear upper portion is made out of a sound deadening material, but doesn't do the same job as the seats would. The bottom, is made from a non sound deadening material, so you will more easily hear things hitting under the car there.
Am I right Stav?
"RICH"
My Build Thread
EURO.TECHNIKS
Old 01-08-2013, 05:44 PM   #7
smares21
My Ride: M3
Make one for the vert please? My backseat is useless anyways.
Clarkson on the 1M: "There's a straight six engine at the front, a manual gearbox in the middle, and drive goes to the back. That's page 1, chapter 1 from the petrosexual handbook."
smares21 is offline   Reply With Quote
Old 01-08-2013, 05:54 PM   #8
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
This looks really nice.
Old 01-08-2013, 06:54 PM   #9
secono330ci
Here's one I just test fitted. All black
Old 01-08-2013, 07:00 PM   #10
secono330ci
Originally Posted by serdar255 View Post
Nice! Bump
Thanks!
I would be lying if I said no, but not by much.
Thanks, I like when things flow well
Originally Posted by Gheybe View Post
Bump. OP puts out.
Am I right Stav?
Yup. Couldn't have said it any better myself.
The top part would most likely fly off with the top down since it's press fitted
Old 01-08-2013, 07:02 PM   #11
smares21
My Ride: M3
Should be easy to add screw mounting tabs...
Old 01-08-2013, 07:17 PM   #12
secono330ci
Probably, unfortunately I don't have a vert around here to test fit it on.
Old 01-08-2013, 07:20 PM   #13
smares21
My Ride: M3
Just post up a thread, I'm sure someone will volunteer if you make it worth their while...
Old 01-08-2013, 07:24 PM   #14
secono330ci
Ok I'll see what I can do
Old 01-10-2013, 12:38 PM   #15
ICONIKE46
My Ride: Horse & Buggy
I really does look clean and is quality work, seen it plenty of times. Saves lots of weight too
BUILD THREAD SOON..IG @: ssblvck_
ICONIKE46 is offline   Reply With Quote
Old 01-11-2013, 11:01 PM   #16
e46craze
Euro.Techniks
My Ride: ESS TS2 ZHP
Send a message via AIM to e46craze
for an awesome guy and great quality work. Takes his time and his work comes out top notch
|ESS TS2|Bimmerbrakes Powdercoated Headers|MB Quart|Memphis|3.46 DIFF
//M3 Control Arms|Orion V2 LED|6K D2S|8K Fogs|//M3 Shift Knob|Eurospec Hamann Front Lip|OEM Cross Drilled Rotors|UUC Stage 3 Clutch/Flywheel|Black Roof|VMR 710s|Dunlop Direzza Sport Z1 Star Spec|Hotchkis Front Sway
FULL I.C.E FOR SALE - PM ME FOR DETAILS (Only Serious Buyers Only)
e46craze is offline   Reply With Quote
Old 01-12-2013, 09:52 AM   #17
BeMyWhip
My Ride: 01 BMW 330ci
What do you use... 5/8" plywood?
Wonder if you can make it lighter using 1/2"?
the goal is weight saving right?
Im sure 1/2" will still hold up if you need to throw someone back there
In an emergency.
Also, maybe you make the front edge 45.
It would flow right into the floor carpet really nice and is really easy to do.
Just thinking at loud. Great work!
Always Mod!!!
Founder: 330Ci The 3 litre coupe
BeMyWhip is offline   Reply With Quote
Old 01-12-2013, 10:28 AM   #18
secono330ci
In an emergency.
I use 5/16's plywood on the bottom. It's the thinnest it could get without wobbling around. It's also perforated plywood which sheds some weight even more. I personally wouldn't put anyone back there period..it's not safe lol.
As for the floor carpet, I'm not sure I understand the 45 degree..it does line up with the edge perfectly though.
Old 01-12-2013, 11:23 AM   #19
BeMyWhip
[QUOTE=secono330ci;15054578]I use 5/16's plywood on the bottom. It's the thinnest it could get without wobbling around. It's also perforated plywood which sheds some weight even more. I personally wouldn't put anyone back there period..it's not safe lol.
As for the floor carpet, I'm not sure I understand the 45 degree..it does line up with the edge perfectly though. [/QUOTE
Ok, well 5/16" is practically a 1/4", wow, cool.
By 45 I meant the front lip where it meets the floor carpet.
You know cut it across use a 45 slant to your circular saw if you use a guide, or a table saw set at 45. Just would make a better transition off the floor to the front edge of the board. Looks great, not knocking your work, just think it would look a bit more polished.
Always Mod!!!
Old 01-12-2013, 08:22 PM   #20
smares21
My Ride: M3
Convertible!!!!!!!!!!!!!!!!!
