Old 03-14-2013, 08:29 PM   #1
ME46SM
My Ride: '04 E46 M3
Leak from differential? (pic)
Hey guys. So I noticed a small oil leak towards the rear of the car. After leaving it in the garage over night, it seems like it only leaked a few drops over night so it's not bad at this time. I am taking the car into a shop in a few weeks to get it looked at but wanted to see if anyone here could give me some clues to what it may be.
Any ideas where it might be coming from? Is it the differential? Any ways to fix without replacement? Thank you all in advance.
04 M3, 58k miles
ME46SM is offline   Reply With Quote
Old 03-14-2013, 10:48 PM   #2
ThatGuy_JZ
My Ride: '02 Steel Blue 325Ci
Send a message via AIM to ThatGuy_JZ
Some M's had a recall for the diff seals.
Also, make sure your axles aren't working their way out from the diff. If so, hit them back in. That happened to me once.
- 2002 Steel Blue 325Ci -
ThatGuy_JZ is offline   Reply With Quote
Old 03-14-2013, 11:08 PM   #3
Stinger9
My Ride: '04 330Ci
Most likely half-shaft seals.
Then driveshaft seal.
Then rear gasket leak.
All repairable; just takes $.
From your question, you'll not be doing this yourself.
Old 03-15-2013, 10:31 AM   #4
mre
My Ride: too many to list
Pinion seal seems to be the most common......somewhere at around 50-60k miles
mre is offline   Reply With Quote
Old 03-15-2013, 10:42 AM   #5
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
The wet spot is at the front of the diff. I'd bet it's a bad input seal. Might as well do the output seals while you're at it, and a fluid change if you haven't already done it.
Old 03-15-2013, 01:29 PM   #6
ME46SM
My Ride: '04 E46 M3
thanks for the help guys
