Old 01-11-2013, 02:57 PM   #21
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Originally Posted by paraklas View Post
Small update.. we noticed that when the DSC/ABS lights flicker, voltage reading jumps to 18v !! Warning lights stop flickering when voltage returns to 14v
Sent from my GT-I9300 using Bimmer App
So, you going to do alt or just the VR?
Upcoming comedy shows: Comic Strip Live, May 12, 6 p.m. & Greenwich Village Comedy Club May 20, 6 p.m. See Facebook for other shows and PM me if you can make one.
dmax on Facebook
Mangofy your E46!
Old 01-11-2013, 04:05 PM   #22
GSherbs
My Ride: 2002 330 xi
Replace VR. Evaluate. Replace alt if necessary.
GSherbs is offline   Reply With Quote
Old 01-11-2013, 04:30 PM   #23
dmax
dmax's Avatar
55,000 miles on the car...you know, it shouldn't be alt, but seems like it.
You've checked all the connections...or will first? I swear, my alt just failed...it was original. Not that that means yours is fine...and it sure sounds like it's wonky, I wonder if a bad ground might lead to high voltage at times...electric isn't my strong suit!
dmax on Facebook
Mangofy your E46!
Old 01-11-2013, 07:58 PM   #24
lcoleman
My Ride: '79 Massey Ferguson
I bet if you checked A/C voltage with a meter, there would be a bit present as well.
Replace the VR. The actual guts of the alt should be fine at that mileage. No ground or poor connection will cause an overvoltage scenario.
Old 01-11-2013, 08:07 PM   #25
dmax
dmax's Avatar
I'd never heard of an overvoltage...sounds like a Voltage regulation issue, but usually alternators fail by producing low voltage.
What's going on that it could break by producing more?
I know Para, so I'm sure the belt was routed correctly! Could some other failure trigger a call for excess voltage...like bad FSR? I'm guessing...again, because I don't recall having heard of an alt putting out high voltage before.
dmax on Facebook
Mangofy your E46!
Old 01-12-2013, 04:53 AM   #26
mkodama
mkodama's Avatar
Nope, only way to do over voltage is with the alternator. It's takes a pretty specialized circuit to bump voltage back up.
Also, it is a somewhat common occurrence. Most often people notice it when the alternator overcharges the battery and you get a rotten egg smell.
Old 01-12-2013, 08:52 AM   #27
shovelit
My Ride: 03 325xi and 04 330x
I'm pretty sure the alternator is capable of putting out 18-20 volts. It's up to the regulator to keep it between 13 and 14.7.
shovelit is offline   Reply With Quote
Old 03-15-2013, 12:38 PM   #28
paraklas
My Ride: ESS TS2 320ci
***update***
Today I replaced the alternator, it was a Valeo 110Ah with a low-mileage used one, same brand/output. Unfortunately I couldn't source a Bosch one and the owner was on very tight budget. Anyway, battery light problem solved so as the weird cluster behavior mentioned a few posts above. Car's back to normal
Thanks for all the help!
