Old 01-08-2013, 02:25 AM   #1
HacksawMark
HacksawMark's Avatar
My Ride: 2014 Subaru XV
Does my headlight pattern look weird?
Looks like I have a "hole" in my projector H7 headlight pattern.
Name:	Headlights with fogs.jpg
ID:	485127   Click image for larger version
Last edited by HacksawMark; 01-08-2013 at 02:35 AM. Reason: spelling and additional info
HacksawMark is offline   Reply With Quote
Old 01-08-2013, 02:27 AM   #2
My Ride: Lexus
That's not the only thing wrong with your pattern. Atrocious to say the least. Aftermarket, correct?
Old 01-08-2013, 02:30 AM   #3
HacksawMark
No I don't believe so. I think they're the original lights that came with the car. I did change bulbs when I bought the car but I'm not sure the bulbs are causing that. Guess I could always swap the bulbs and find out.
Old 01-08-2013, 02:43 AM   #4
My Ride: Lexus
That doesn't look like factory projection. theres hotspots and flare galore. did you put an hid kit in there or something?
Old 01-08-2013, 02:50 AM   #5
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
that is really bad - as said, the entire light pattern is screwed up
/_________\
O==[][]==O
Old 01-08-2013, 02:59 AM   #6
HacksawMark
No HID kit. The headlights are not HIDs, they're H7 bulbs in non-xenon projectors.
Old 01-08-2013, 03:11 AM   #7
HacksawMark
I definitely want to upgrade my headlights to something better because the ones I have now are crap. I'm real leery about aftermarket lights though. I may just breakdown and get OEM replacements.
Old 01-08-2013, 07:44 AM   #8
WDE46
My Ride: '13 128i, '04 330Ci
I would try taking them apart and inspecting it. If you are going to get new ones then you might as well try it. You'll have to put them in the oven to release the seal for the clear lense though.
Have you tried moving the lights through their various ranges of adjustments? I mean full left, full right, all the way up and down. Does that blank spot stay in the same place?
Old 01-08-2013, 08:47 AM   #9
HacksawMark
I have made some adjustments; the left side was was too low to begin with. I can only adjust them up and down, no side to side adjustment. When I adjusted them, the blank spot moved with the adjustment. I'm not going to go the oven route to unseal the lenses; I have trouble burning cookies when I bake.
Old 01-08-2013, 09:01 AM   #10
jfoj
My Ride: 330CiC, M5, X5, E93
There should be both vertical and horizontal adjustment for each light assembly. You should have 2 adjuster screws for each side of the car.
You should also back at least 20-25 feet back away from the wall/door and take another picture of your pattern as it is sometimes hard to see the pattern up so close.
Even non HID projectors have the sheet metal shields in the bottom of the projector to control the upper level cut off to with the stair steps. At least quality projectors have this feature.
Make sure that your headlight assemblies have not been swapped out with some less than quality aftermarket assemblies. Look for the letters Depo somewhere in the plastic lens, this would indicate they are not original headlights.
I see you have a 2006 coupe, I know HID was as option as my 2006 Vert has Active Bi-Xenon that actually turn with the steering, not sure what the standard headlights were for 2006 coupes?
Old 01-08-2013, 09:02 AM   #11
choxor
My Ride: JDM
Holy crap. Do you have pics of your headlights? We can probably tell if they're OEM or not.
Old 01-08-2013, 09:04 AM   #12
WDE46
The standard lights are H7 size bulb halogen projectors with halogen dish highbeams.
You are correct that there is a left/right and up/down adjustment. The left/right adjustment is nearer to the front quarter panel of the car than the up/down adjuster.
Old 01-08-2013, 09:11 AM   #13
HacksawMark
I will take new photos and post. Will also examine the lenses again to see if they are depos. Not sure why the previous owner would have switched out oem projectors for Depo projectors...
I will also take photos of the headlights and post.
Old 01-08-2013, 09:13 AM   #14
HacksawMark
Any idea where I can get a photo or illustration of that adjustment?
Old 01-08-2013, 09:23 AM   #15
WDE46
I can make one. Thank god ECS Tuning has the best part photos in the business.
For the left/right one you can turn the grey screw on top or that black one on the back. While it's on the car you can only turn the grey one.
Old 01-08-2013, 09:52 AM   #16
jfoj
Accident?? fogged/yellowed lens??
Old 01-08-2013, 10:45 AM   #17
BimmersGarage
My Ride: E46 330i
Is there any damage/scuffs on the reflectors? Post pics of actual headlights..
BimmersGarage is offline   Reply With Quote
Old 01-08-2013, 10:49 AM   #18
trizzuth
My Ride: 231k, 16yr old B3AST
Looks to me like a half burned out bulb issue making that weird shadowy circle area.
I have DEPO projectors and there is the metal thing on the back of the glass projector sphere that has the stair steps that flips itself upside down when light is passed through the sphere.
trizzuth is offline   Reply With Quote
Old 01-08-2013, 11:45 AM   #19
HacksawMark
My headlights don't have the adjustment knobs. I will post photos when I get a chance.
Old 01-08-2013, 11:49 AM   #20
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Can you post pics of the actual headlight please
