Australia
Old 01-08-2013, 04:18 AM   #1
DeclanM3
My Ride: 332Ci
Screw In My Tyre >_<
Hey guys,
Ran over a bloody screw in the M3. Don't think it's repairable since it's so close to the side wall, mind you it's a small screw. What do you guys reckon? Am I screwed and need to buy a new tyre or reckon someone will repair it?
DeclanM3 is offline   Reply With Quote
Old 01-08-2013, 04:20 AM   #2
DeclanM3
My Ride: 332Ci
Is it worth putting the car on jack stands to prevent it from sitting on the flat tyre for a couple of days until the weekend when I can get it fixed?
Old 01-08-2013, 05:06 AM   #3
SCE46
My Ride: M3
Yeah, it's screwed.
BMW E46 M3
BMW E83 X3
BMW E46 Supercharged - Sold
BMW E30 SR20DET - Sold
SCE46 is offline   Reply With Quote
Old 01-08-2013, 05:20 AM   #4
Brissyjohn
My Ride: 2007 MX-5
Take it to a tyre place for their opinion. Can you keep it inflated or is it a rapid leak?
Brissyjohn is offline   Reply With Quote
Old 01-08-2013, 05:27 AM   #5
Casho
My Ride: e90 330i
I just had a broken bottle pierce my tyre too. I'd say you have a 50% chance of repair on that since it is a small hole and not on the sidewall but very close.
Casho is offline   Reply With Quote
Old 01-08-2013, 06:04 AM   #6
vwikit
My Ride: 318i 99
you can get it repaired if you see someone good and the belt isnt damaged. i had one closer to the side wall and they rubber welded it. but they do have to take the tyre off the rim for that.
vwikit is offline   Reply With Quote
Old 01-08-2013, 06:24 AM   #7
DeclanM3
My Ride: 332Ci
It holds pressure alright. I'm going to take it to some tyre shops on the weekend to see what they say. I've also requested quotes for two new tyres.
It's up on jack stands for now to prevent any structural damage to the tyre. Hopefully body corp don't kick up a stink. Rears are only an inch off the ground and the fronts are chocked.
Old 01-08-2013, 08:05 AM   #8
KOpower
My Ride: 325ci
go to a big tire shop - very good chance of repair - this shiz happens!
My Ride:
2002 e46 325ci Manual - Sport & Premium Pkg
KOpower is offline   Reply With Quote
Old 01-08-2013, 08:20 PM   #9
11EAS
My Ride: M3
Nah I think you should be sweet Declan..
'04 JB/IR M3
11EAS is offline   Reply With Quote
Old 01-08-2013, 08:24 PM   #10
mkodama
mkodama's Avatar
Have it plugged, it'll probably be fine.
Old 01-08-2013, 08:35 PM   #11
rcsummers
My Ride: M3
not worth getting it plugged, to close to the sidewall.
buy a new set of rears.
"RICH"
My Build Thread
EURO.TECHNIKS
- Status Gruppe Tuning - Broadway Static - Recaro - DTM Fiberwerkz - AutoCouture Motoring -
Instagram: @summers_e46_m3
Twitter: @rcsummers0506
Xbox One: MisterMeisterM3
rcsummers is offline   Reply With Quote
Old 01-08-2013, 08:54 PM   #12
DeclanM3
My Ride: 332Ci
Why do you say it's not worth getting fixed?
I'm no tyre engineer but I can't see how a 2mm diameter hole with a depth of no more than 4-5mm would cause any structural damage should it be plugged. I drove on the tyre for no more than 500m after the TPMS went off and it still had 30PSI in it when I got home. It's now on jack stands so I can't see why it would be beneficial to bin them and get new tyres if I can get the hole plugged to a point where it will hold pressure.
Keen to hear your reasoning if you think otherwise though.
Old 01-08-2013, 08:58 PM   #13
Mallee
My Ride: 2002 E46 M3
I'll start this with "in Australia"
Any puncture within 2cm of the tyre wall is considered "unrepairable" by the large tyre distributors/chains.
When you finally find a smaller repairer who will fix it, they will usually say, "yes but we won't guaranty the repair will hold." I was told around 50% chance, it's because there is a lot of flex in the tyre in that area during acceleration, breaking and cornering.
I had a screw puncture my rear tyre in an almost identical position on a new Michelin ps2, I had it repaired and it held up fine. (it took me 4 different Tyre stores to find one that said it could be done.)
I'll admit I was a little concerned about what could happen if I tracked the tyre, so I replaced it when the tyre reached 1/2 tread, however I probably could have continued using it with no concerns.
Mallee is offline   Reply With Quote
Old 01-08-2013, 09:11 PM   #14
Mallee
It's pretty simple.
There are kevlar (?) threads in the tyre side wall and if they are damaged, the tyre then has a weak point where is can explosively blow out, which obviously is dangerous when your going fast around a corner..
Which is also when you're most likely to cause the blow out, obviously that is when your'e loading the tyre the most, further that location is also near the maximum stress point for the tyre during acceleration and breaking.
The reason it may not be worth patching relates to the cost of the patch, time to patch failure, (which they won't re-patch as I understand it), and danger of blow out, a serious blow out could cost you more than just a new tyre. (ie injury to yourself and others, or just extra damage to the car)
I find them all to be good arguments, but I still had mine repaired and was happy with the result.
In my case and from what I can see of yours, the entry of the screw appears not to touch the sidewall, and I found the risk acceptable, BUT the shoulder is a weak point in the tyre, and the patch further weakens it.. Thankfully it's not in the side wall.
Old 01-08-2013, 10:55 PM   #15
pythonis
My Ride: BMW 2000 323CI
When that happened to me it cracked my wheel and i had to get it welded shut new wheels i bought dont fit either so they have to be machined. Lucky that it will only be your tire that needs replacing
pythonis is offline   Reply With Quote
Old 01-08-2013, 11:34 PM   #16
DeclanM3
My Ride: 332Ci
I'm lost, what cracked your wheel?
Old 01-09-2013, 06:00 PM   #17
KOpower
My Ride: 325ci
Good to see your tyre pressure sensors working well and doing their job!
My Ride:
Old 01-09-2013, 06:24 PM   #18
DeclanM3
My Ride: 332Ci
Yeah. I was surprised at how quickly it picked up the fault considering the way the system works. The pressure when the light came on would've only dropped by a few psi max.
Old 01-13-2013, 05:46 AM   #19
pythonis
the screw in the tyre... silly billy
Old 01-13-2013, 05:51 AM   #20
trive2
My Ride: 1989 BMW 535i
I would just plug it. My Jewish overrides safety concerns.
But id suggest a new tyre, particularly under hard driving.
trive2 is offline   Reply With Quote
