General Off-Topic
Old 12-19-2010, 10:27 AM   #1
yellow325ix
My Ride: 325ix, 750i
Send a message via AIM to yellow325ix
Garage Lifts
Guys,
I am looking for a lift for one of my stalls. I want to store my E30 and Datsun in the same spot. Need it both for storage and under carriage access to work on them both. I will be driving in and out so it needs to be practical and provide plenty of clearance. I have seen the pictures in the ultimate garage build threads but they don't discuss 2 post vs 4 post benefits.
What have you done, what works the best?
Thanks,
Tim
yellow325ix is offline   Reply With Quote
Old 12-19-2010, 10:46 AM   #2
rsxstock
My Ride: 2001 325ci
0:28
seems like 4 is safer but for either one you'll need a good foundation
rsxstock is offline   Reply With Quote
Old 12-19-2010, 10:49 AM   #3
yellow325ix
Yeah, that's ugly. 4 post seems better for sure. The backyard buddy offerings do not even have to be bolted to the floor.
Anyone have experience with them?
Old 12-19-2010, 11:07 AM   #4
rsxstock
My Ride: 2001 325ci
i see a lot of ppl using them. they seem very safe based on the wide column base
Old 12-19-2010, 05:06 PM   #5
Starfire Auto
Past Site Sponsor
My Ride: W/E I have in stock
4 post doesnt let you work on the brakes/suspension/bushings. you would need to get another jack to lift the wheels. It does let you work under the car for oil changes/trans work/exhaust work.
2 post...yeah ive seen them fail but i would think its RARE. You have to get a 2 post professionally installed, you dont need an install on a 4 post
I use a mid rise lift at my shop. I dont spend a lot of time under it and it was only $500 (used, $2500 new). Pro: its easy, quick and simple 110v. Con: hard to access transmission and only goes about 4' high. Pic:
Starfire Auto is offline   Reply With Quote
Old 12-19-2010, 05:28 PM   #6
Coldintake
Registered OG User
My Ride: Mid-engine beast
I would imagine you need substantial clearance on either side for a 2/4 post. I don't know if you have a 3 car garage and you want to use the middle one or something smaller?
Whatever you do, take your time, do your research and get some pros to do the job. I can't imagine anything more dangerous at home than a falling car.
Coldintake is offline   Reply With Quote
Old 12-19-2010, 05:31 PM   #7
yellow325ix
Are 2 posts really designed for long term storage of a vehicle? Seems like they are made for working on a car but not holding one in the air for months at a time. What do you think?
Old 12-19-2010, 06:05 PM   #8
TrickTizzle
My Ride: 325i
2 post.
You can't work on suspension with a 4 post.
Old 12-19-2010, 07:19 PM   #9
Guest100615
Account closed per your request
Can you imagine the phone call to the owner of the van ?
Good afternoon Mr. Smith, uhhhhhhhhh, we had a little problem with your van today....
It is not going to be ready when we promised this afternoon.
Allow me to explain why, better yet.....I'll let you speak to my supervisor.
Guest100615 is offline   Reply With Quote
Old 12-19-2010, 07:30 PM   #10
yellow325ix
Originally Posted by TrickTizzle View Post
2 post.
Same question, can you use a 2 post for long term vehicle storage. From what I have read, nobody says no but nobody says that you can do it.
Thoughts?
Old 12-19-2010, 07:37 PM   #11
TrickTizzle
My Ride: 325i
Thoughts?
I don't see why not. The lift locks when its up.
Old 12-19-2010, 08:16 PM   #12
grkm3
My Ride: Money Pit
Send a message via AIM to grkm3
^^ this. As long as it's sitting on the locks I dont see a problem. Now, what happens if you store it for the Winter and when you go to lower it in the Spring the hydraulics are messed up? Like if one of the pistons was leaking.
SOLD
03 Steel Gray M3 - Imola Red Interior - SMGII - Premium - HK Sound
Mods: VFE SC Stage 2, SS Ceramic Coated Stepped Headers, S-Pipe, X-Pipe, TMS Subframe Reinforcement, KWV2 Coilovers, TMS Camber Plates, Powerflex RTAB's, Rogue RSM's, ZCP F/R brakes
Coming Soon: Open to suggestions
grkm3 is offline   Reply With Quote
Old 12-19-2010, 08:29 PM   #13
TrickTizzle
My Ride: 325i
When the lift is locked its not really relying on hydraullics.
And also I read one of the guys said 4 post is safer, despite what you may think, 2post are much safer and have a higher load rating.
Old 05-11-2012, 09:03 PM   #14
yellow325ix
Finally breaking ground on Tues, turning my 3 stall into a five stall...now I will have plenty of room for a lift.
Any new thoughts on the best way to go?
Old 05-11-2012, 09:35 PM   #15
00stephen
My Ride: '02 TJ, '87 Milano
Sounds like a four post for storage and non-suspension work, with a midlift tucked away for anything else.
00stephen is offline   Reply With Quote
Old 05-11-2012, 09:37 PM   #16
yellow325ix
I think that one is all that I will do
Old 05-11-2012, 10:43 PM   #17
Lexie330ci
ILCUTAWOOTIE
Lexie330ci's Avatar
My Ride: 330ci
Send a message via AIM to Lexie330ci
check costco.com
Need brakes? Bother Anthony Here!
Lexie330ci is offline   Reply With Quote
Old 05-12-2012, 01:39 AM   #18
Dibaltic
My Ride: 325ci
my dad has a 2 post lift in his garage. every winter we store a car on it for 3-4 months straight. never have had a problem doing this
Dibaltic is offline   Reply With Quote
Old 05-12-2012, 01:43 AM   #19
E46330iguy
My Ride: Supercharged 330i
You can work on suspension with a 4 poster, Most of them have rails with 2 air powered jacks one in the front and one in the pack so you can lift the wheels off the ground, Most tire change places use them and the work fine and also have locking systems
Winter Authority When Hell freezes over,we'll play Hockey there too
you've Met a terrible fate haven't you ?
KONI /Michelin/Stoptec/Borla/ Bimmerbrake / MTechII/AA Stage one (for now) Automatic--->5 speed swap/ UUC High performance clutch kit
Questions about Header wrap? clickHere
Supercharger build thread click Here
E46330iguy is offline   Reply With Quote
Old 05-12-2012, 01:58 AM   #20
ANREC330
My Ride: C6 Vette & M3
2 post will be fine. Only way I see a 2 post failing is by leaving a full sized truck or suv on it for long periods at a time.
ANREC330 is offline   Reply With Quote
