///M3 Forum
Old 01-08-2013, 10:37 AM   #1
Ntrb8s4
My Ride: X5 / B8 S4
Hello e46 m3....
Just wanted to say hello! I'm new to the e46 m3 and after having this car for a few days I really have to say its awesome! What a huge difference between my s4. This car handles like a real sports car. From all that I've been reading on here that there's not much to do performance wise on these cars. I like this car a lot but I feel like its missing something(power wise). I think the first buy I need to make is a set of staggered 19".
Ntrb8s4 is offline   Reply With Quote
Old 01-08-2013, 11:13 AM   #2
scca_ziptie
My Ride: 2006 M3 SMG Comp pkg
Welcome and congrats on the car. In terms of performance, the 19's won't make any kind of real noticeable difference - but they'll more than likely look good. 3 things to do first on the car to improve performance: differential (diffsonline), flywheel (lighter and singlemass), and an ecu tune (like from ESS). Exhaust and intake doesn't really make a huge power gain (typically) but you will hear a difference so it may feel to you like you got more than you actually did.
Congrats again, learn to utilize the search feature on this forum as it will become your friend for DIY and other things (lots of good info).
Don
"! First rule of Italian driving, that which is in your mirror is not important !"
scca_ziptie is offline   Reply With Quote
Old 01-08-2013, 12:13 PM   #3
Ntrb8s4
My Ride: X5 / B8 S4
Don
Thanks for the info on the tune. That maybe one of the first performance mods for me!
Old 01-08-2013, 12:22 PM   #4
scca_ziptie
It's like $700 from ESS and you are able to remove the speed limiter, tune for 91 octane US grade fuel and change the rev limiter (you must specify as they will leave it at 8200 if you don't tell them otherwise). I personally wouldn't go higher than 8500 but they will take it as high as 9000 if you chose to do so. They say approx 10 hp gains with the tune.
Old 01-08-2013, 12:25 PM   #5
Ntrb8s4
My Ride: X5 / B8 S4
Yeah, I don't think I'd want to go higher that 8500. $700 is pretty high for 10hp! This is a lot different to get horse power out out of.
Old 01-08-2013, 01:12 PM   #6
scca_ziptie
Ya, BMW did a pretty bang up job with this engine. The drive-ability and throttle response are improved along with that tune for sure, they also say that the fuel economy is slightly improved although I have not really been able to personally verify this aspect. They say "10-15" hp gains are to be had, but I always go on the low side of what a company says the gain is.... Naturally aspirated engines are not nearly as easy to increase power output compared to turbo/supercharged platforms. That being said, you can certainly aspirate the S54 but the cost is definitely not in the same solar system....
