Old 01-08-2013, 01:10 PM   #1
jay786
My Ride: 318CI
Exclamation Higher Gear Ratio Diff!
Hi there,
I have a 2002 plate BMW 318CI Manual and my diff needs to be replaced. Can i install a diff with a ratio of 3.73 or higher? What are the benefits and flaws of installing a diff with a higher gear ratio?
What is the ratio for a standard 318CI?
Many Thanks
jay786 is offline   Reply With Quote
Old 01-08-2013, 01:19 PM   #2
mwt330i
My Ride: 2004 330i 6speed
Yours may have been originally 3.45 according to bokchoys web site.....going a bit higher to the 3.73 would improve your low end acceleration but cost you a tiny bit in highway RPM's (higher rpms at speed).
mwt330i is offline   Reply With Quote
Old 01-08-2013, 01:22 PM   #3
jay786
My Ride: 318CI
the 3.73 diff is from a 1 series but its the same fit ... would it cause any problems?
Old 01-08-2013, 01:39 PM   #4
white46
My Ride: e46 323ci
I don't think it's going to cause as problems as long as it's direct fit, and if you can live with higher rpm at higher speed.
white46 is offline   Reply With Quote
Old 01-08-2013, 01:46 PM   #5
jay786
My Ride: 318CI
whats the problem with higher rpm at high speeds ... obviously drinks more petrol ... what else?
Old 01-08-2013, 01:48 PM   #6
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
Higher ratio differential
Pros:
better acceleration
Cons:
higher fuel consumption
reduced top speed
more shifting
increased wear on drivetrain components
Old 01-08-2013, 03:04 PM   #7
RayPooley
My Ride: 320i SE Coupe
Originally Posted by jay786 View Post
Hi there,
Many Thanks
You all seem to be ignoring an obvious constraint. Its not all about ratio. Its about power throughput and heat dissipation. For example, if you took the diff from a 1.6L and strapped it to a 3.0L I wouldn't be surprised if the thing glowed in the dark. If you have a 1.8L then pick a diff from a 1.8L or above and then consider the ratio.
Old 01-08-2013, 04:03 PM   #8
Alex323Ci
My Ride: M3 & 323Ci (sold)
you should have a 3.38 ratio now. im pretty sure that's the small pumpkin diff, so you could go to the 3.91 for a jump. the 3.45 would be so slight i would not do it unless old diff was blown.
if the 3.73 fits then that would be a ~10.4% change.
the 3.91 would be ~15.7% change
Old 01-08-2013, 04:14 PM   #9
Alex323Ci
no it won't be that issue of heat dissipation. besides OP has a 318Ci's, that use 3.38 and 3.45 ratios. He's not going the other way around.
In your example of a 330 retrofitting a 318Ci diff, the issue would be they use a smaller diff and not as strong on launch. Not about heat like you espress. Race teams often use a smaller diff for less weight
Old 01-08-2013, 05:12 PM   #10
RayPooley
I disagree. I have seen diffs explode through overheating. Seals burst, bearings fail, oil escapes and boom. Gears shatter. Gears are just like bearings. You overload them and they will fail. Its not something you can just ignore theoretically speaking.
Old 01-08-2013, 05:47 PM   #11
E46 Coupe
E46 Coupe's Avatar
My Ride: Rules1 & 2: S T F U!
tmk the 318 and 320 diffs have smaller output flanges...
Came across this on my search for specific ratios and a 320 diffs output flanges did not mate up to my 323.
E46 Coupe is offline   Reply With Quote
Old 01-08-2013, 07:12 PM   #12
Alex323Ci
yes diffs do fail, just like any other mechanical component. your example is of a failure of a seal and loss of fluid running dry, not that the diff was unable to overcome it's duty. or that it wouldn't be able to handle the 3L engine and glow from getting hot. any differential, be it out of the smallest engined 4 cylinder E46 to 3.2L if run extremely low or dry will fail.
tell me how much turning does a 3.38 diff do in a 318Ci compared to a 330Ci ?
but all this still does not matter in the topic at hand where the Op would be going with a larger diff compared to smaller.
Old 01-08-2013, 07:41 PM   #13
wildirish317
My Ride: 2004 325Ci vert
Lower top speed, as you'll hit your rev limiter at a lower speed. If that doesn't bother you, and the higher fuel consumption doesn't bother you, then go for it.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 01-08-2013, 09:08 PM   #14
Alex323Ci
"theoretical" top speed.
i don't know of anyone who has run out of revs for their car before running out of engine power to overcome wind, air and rolling resistence. when this happens is the actual "top speed" of any given car.
but the car will absolutely rev higher in it's final drive gear. but it's not a given that one's top speed will suffer. on a 318Ci which factory spec does 135mph i seriously doubt it.
Old 01-08-2013, 09:28 PM   #15
wildirish317
You're probably right. Going from a 3.38 to 3.73 will increase his speed in any gear by about 10%. This means that he'll be at 6,600 rpm at the same speed he used to run 6,000 rpm.
I have to confess, I've never pushed my car anywhere close to 6,000 rpm in 5th gear (5 speed).
Old 01-09-2013, 11:09 PM   #16
Alex323Ci
thanks for reading and using information given to reassess and answer.
all too often on this forum people will just argue a point when reasonably one can see it's just not so.
Old 01-10-2013, 06:30 AM   #17
RayPooley
May I just clarify that? The change will effectively move the car further for one rev of the engine in any gear. So what that means is it will be doing a greater linear velocity at 6000 rpm than it used to. 10% is it? Its not a matter of greater rpm for a given linear velocity. Its the other way round. Its lower rpm for a given linear velocity. Fewer turns of the crankshaft per unit of distance covered. This does, of course, raise an issue regarding the speedometer. Will the speedo still reflect the true linear velocity of the vehicle after the change? In essence, at 2500 rpm (56mph?) you might be travelling faster than your speedo tells you and if there's a cop with his speed gun aimed at you that might cost you some dollars.
Old 01-10-2013, 07:26 AM   #18
NOVAbimmer
My Ride: E60M
Your overly-complicated explanation aside, it would only matter for speed if the speed sensor were on the output flange of the transmission.
NOVAbimmer is offline   Reply With Quote
Old 01-10-2013, 07:29 AM   #19
NOVAbimmer
My Ride: E60M
And increasing your differential ratio will decrease your road speed for a given engine speed in a gear.
Old 01-10-2013, 07:32 AM   #20
RayPooley
So when we are talking about diff ratios the ratio is given as output : input rather than input : output. Is that right?
EDIT:
"It's the ratio of how many times the drive shaft turns to how many times the axle turns and is set up by choosing how many teeth are on the ring and pinion gears."
So it is the ratio of input to ouput. But its based on rotations : rotations not teeth : teeth. I see. I am assuming the ratio is teeth : teeth which, in the case of diffs, is incorrect.
