Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > NY / NJ / CT
NY / NJ / CT
NY NJ CT
Old 02-26-2013, 12:09 AM   #1
JaySpec7
My Ride: 01' 330Ci & 04' X5
Send a message via AIM to JaySpec7
23" Apple Cinema HD Display
Excellent Condition...
Had it listed for $400 originally but now i'm looking for $275 for a quick sale.
Specs
23 inches viewable
Thin film transistor (TFT) active-matrix liquid crystal display (AMLCD)
Resolutions 1920 x 1200 pixels (optimum resolution), 1280 x 800 pixels, 1024 x 640 pixel
Display colors (maximum) 16.7 million
Viewing angle (typical) 170 horizontal; 170 vertical
Brightness (typical) 270 cd/m2
Contrast ratio (typical) 400:1
Response time (typical) 16 ms
Pixel pitch 0.258 mm
Screen treatment Antiglare hardcoat
User controls (hardware and software) Display power, system sleep, system wake, brightness and display tilt
Cables DVI (Digital Visual Interface), FireWire 400, USB 2.0 and DC power (24.5 V)
Connectors Two-port, self-powered USB 2.0 hub, two FireWire 400 ports and Kensington security port
VESA mount adapter Compatible with VESA FDMI (MIS-D, 100, C) compliant mounting solutions. (Requires optional Cinema Display VESA Mount Adapter
Technical Specifications and Approvals
Electrical requirements
Input voltage: 100-240 VAC 50-60Hz
Maximum power when operating: 65W (Apple Cinema Display); 90W (Apple Cinema HD Display); 150W (Apple Cinema HD Display)
Energy saver mode: 3W or less
Environmental requirements
Operating temperature: 50 to 95 F (10 to 35 C)
Storage temperature: -40 to 116 F (-40 to 47 C)
Operating humidity: 20% to 80% noncondensing
Maximum operating altitude: 10,000 feet
Size and weight
23-inch Apple Cinema HD Display
Height: 17.7 inches (45 cm)
Width: 21.1 inches (53.6 cm)
Depth: 7.3 inches (18.7 cm)
Weight: 15.5 pounds (7.03 kg)
Agency approvals
FCC Part 15 Class B
EN55022 Class B
EN55024
VCCI Class B
AS/NZS 3548 Class B
CNS 13438 Class B
ICES-003 Class B
MPR II
IEC 60950
UL 60950
CSA 60950
EN60950
ENERGY STAR
TCO 03
JaySpec7 is offline   Reply With Quote
Old 02-28-2013, 11:39 AM   #2
JaySpec7
price drop to $275
