Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > NY / NJ / CT
NY / NJ / CT
NY NJ CT
Old 01-08-2013, 08:33 PM   #1
NJfistpumpin
My Ride: 325i
Coil over install
Hey anyone do coil over install in NJ? I am putting in some new ones and would much rather watch someone do it to learn then pay a shop.. Pm me with how much you'll charge I'm in Middletown NJ can do it in my garage or your choosing. LMK...
4 Doors
NJfistpumpin is offline   Reply With Quote
Old 01-08-2013, 09:57 PM   #2
secono330ci
My Ride: 04' 330ci & 99' 540i
What coils did you get? I can do the install for a good price.
secono330ci is offline   Reply With Quote
Old 01-08-2013, 10:08 PM   #3
NJfistpumpin
My Ride: 325i
Ill be getting KW V2s in two weeks. I'd need to set up a day where I can get the install done and then ship out my stock sport suspension the next day. Ill be reusing top mounts and bolts
4 Doors
Old 01-08-2013, 10:35 PM   #4
secono330ci
Ok that's perfect. V2's are great you're gonna love them.
You're going to need adjustable end-links as well.
Old 01-09-2013, 02:44 AM   #5
NJfistpumpin
My Ride: 325i
What's a good brand of end links? And where should I get them? Sorry I'm that oblivious to suspension installs.. Engine,electric, hardware I do all myself, spring force rubs me the wrong way
4 Doors
Old 01-09-2013, 03:20 AM   #6
peytonracer4
My Ride: '00 328i
He shouldn't need adjustable ones unless he's going crazy low.
I'm pretty low with no gap all around and I run the stock length end links.
choose to click or forever hold your piece ;)
Old 01-09-2013, 03:41 AM   #7
secono330ci
Anything lower than 1.5" will put extra stress on oem sized links. I've had them snap on me in the past.
Old 01-09-2013, 08:06 AM   #8
peytonracer4
My Ride: '00 328i
Why would it put extra stress on them? There shouldn't be any preload on them at all. So a car sitting still shouldn't be putting any force on them.
Old 01-09-2013, 09:23 AM   #9
dji203
My Ride: Z4 Coupe, G35x
If you do want adjustable end links, go for the Bimmerworld ones. I got the E36 adjustable ones (e36 are lower than e46) but e46 adjustable ones will go lower than what you have now. I only went e36 because I needed to shortest as possible.
Recaro | AST | Vorshlag | Quaife | Performance Friction | Autosolutions | BMW Performance
Click here for my track videos
dji203 is offline   Reply With Quote
Old 01-09-2013, 10:50 AM   #10
secono330ci
You are absolutely right about no preload.
But on KW's (and most coils for that matter) the endlink housing on the strut is lower than the endlink housing on an oem strut. Therefore needing a shorter endlink.
KW:
OEM e46 non-m:
Old 01-09-2013, 10:57 AM   #11
secono330ci
+1 on the bimmerworld
Old 01-09-2013, 11:17 AM   #12
Barbaros
My Ride: 328i
Yes he is going to need shorter endlinks. Since you are there, you might as well get; front tower reinforcement plates, new front & rear shock mounts.
Barbaros is offline   Reply With Quote
Old 01-09-2013, 11:51 AM   #13
NJfistpumpin
My Ride: 325i
Wow guys, thanks for all this info!! Ill order the Bimmerworld ones and def the reinforcement parts. Trying tithe right, and do it once. Plus learn a bunch in the process
4 Doors
Old 01-09-2013, 02:27 PM   #14
peytonracer4
My Ride: '00 328i
KW:
OEM e46 non-m:
Ah did not know that. Thanks for the info
Old 01-09-2013, 04:44 PM   #15
NJfistpumpin
My Ride: 325i
So should I order the e36 end links or the e46 ones? And do I need front AND rear?
4 Doors
Old 01-09-2013, 06:46 PM   #16
secono330ci
Order the e46 ones they'll do fine. And only the front's fine.
Old 01-11-2013, 12:33 PM   #17
dreamteam1000000
My Ride: 2003 x5 (e53)
are these end links needed for any suspension ur putting on ? my cousin is throwing some race lands on his car would he be needing those to
e46
dreamteam1000000 is offline   Reply With Quote
Old 01-11-2013, 10:58 PM   #18
e46craze
Euro.Techniks
My Ride: ESS TS2 ZHP
Send a message via AIM to e46craze
Your in excellent hands with secono330ci. He has worked on my car numerous times and you will learn alot
|ESS TS2|Bimmerbrakes Powdercoated Headers|MB Quart|Memphis|3.46 DIFF
//M3 Control Arms|Orion V2 LED|6K D2S|8K Fogs|//M3 Shift Knob|Eurospec Hamann Front Lip|OEM Cross Drilled Rotors|UUC Stage 3 Clutch/Flywheel|Black Roof|VMR 710s|Dunlop Direzza Sport Z1 Star Spec|Hotchkis Front Sway
FULL I.C.E FOR SALE - PM ME FOR DETAILS (Only Serious Buyers Only)
e46craze is online now   Reply With Quote
Old 01-11-2013, 11:14 PM   #19
secono330ci
Yup he'll need them
Old 01-11-2013, 11:16 PM   #20
secono330ci
Thanks Chris
Yo on a side note I got a cam tool..you know what that means..ts2+
