Old 01-09-2013, 01:18 AM   #1
seigi009
My Ride: 03 325i
How can I tell if my new water pump is working properly?
So, I just replaced my water pump (graf), water pump pulley (uro aluminum), idler pulley and belt. After replacing coolant (BMW 50/50 w/ distilled) and bleeding, I started her up and heard/felt a bump coming from the engine. It got me thinking that maybe something happened to the water pump but I can't tell if it is working. I took it for a 10mile test drive and the temp needle never strayed from the middle and my heat works perfectly.
I was told that if you see a small stream of water running into the expansion tank then your pump is good. Well, my old pump stopped making the stream of water into the expansion tank so I replaced it with the Graf one with a metal impeller but I still don't see a stream either when the car is cold or warm. Do I have some clog somewhere?
I am at 120k and my expansion tank is original (replacing next month) and so are my upper and lower hoses. Thermostat was replaced last year.
I searched high and low for an answer before posting this so any help would be most appreciated. Thank you.
seigi009 is offline   Reply With Quote
Old 01-09-2013, 02:34 AM   #2
My Ride: 2016 Lexus
if your car isn't overheating, your pump is working.
if it spins, it's working.
Old 01-09-2013, 07:15 AM   #3
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
make certain the coolant system and engine are completely bled of air or you will not see that water stream
/_________\
O==[][]==O
