Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 01-16-2013, 11:48 AM   #41
MKampa
My Ride: B7 Audi A4
Originally Posted by Commanderwiggin View Post
No...they are not.
Looking at 13k without EMS...without fuel system...
so add on 3100 for the basic EMS without CAN display, I-boost, etc..
we'll say about 1200 for flex fuel sensor, can display, I-boost
add on 3600 for the Saad fuel system with pumps and injectors
And then there is a clutch...so anywhere from 1k-3k
So for the basic setup without subframe reinforcement...upgraded mounts, Saad ignition system and alot more "recommended items"... You're over 20k just to start without an engine build.
This is by far the most expensive option...by far and I wouldn't even say it's at quality to even consider spending that much...
So the basic HPF tuner kit with intercooler setup is $6000...SAAD tuner kit is $13000 ...the only big differences is the oil sump and tubular exhaust manifold...which for a non-built motor is pointless.
Now for 10k...you can get a full DME tuned setup with MaxPSI which is by far one of the best setups money can buy.
And then you have the FSR setup which very well may blow the HPF/Saad options away as far as quality and performance goes...pricing yet to be released but with the level of work they've been putting into their kit...it should be damn near perfect.
Regardless looking forward to seeing another boosted M on the road, just wanted to clarify some pricing so people are more aware
You all are misinformed, the Saad Racing Stage 3 kits makes 940 hp to the tire and is proven in jasons car, in order to get that kind of horsepower out of an HPF kit you are looking at $49k!! And as far as maxpsi kit i have not seen their kit make over 500 hp, and personally i see a lot of flaws in that kit. Saad Racing sets records and is a game changer in the E46 M3 Turbo market.
MKampa is offline   Reply With Quote
Old 01-16-2013, 12:03 PM   #42
6spd_legend
My Ride: acura legend 6spd
Originally Posted by MKampa View Post
You all are retarded, the Saad Racing Stage 3 kits makes 940 hp to the tire and is proven in jasons car, in order to get that kind of horsepower out of an HPF kit you are looking at $49k!! And as far as maxpsi kit i have not seen their kit make over 500 hp, and personally i see a lot of flaws in that kit. Saad Racing sets records and is a game changer in the E46 M3 Turbo market.
The Saad Racing Stage 3 kit makes 940 rwhp on a stock block?
2001 LSB M3 Coupe
6spd_legend is offline   Reply With Quote
Old 01-16-2013, 12:06 PM   #43
MKampa
My Ride: B7 Audi A4
Saad Racing and HPF stage 3 both require built engines, we are comparing stage 3 builds correct?
Old 01-16-2013, 12:14 PM   #44
Commanderwiggin
My Ride: 1000rwhp Turbo M3
You sir...are retarded...but if you want to compare built blocks it is still half the price as the saad setup.
Go stick it in your ass.
And I was comparing basic setups on a non-built motor.
With or without EMS it's half the cost...
Old 01-16-2013, 12:27 PM   #45
E85head
My Ride: E46 M3
I think if prices don't change. Max PSI is going to sell a lot of kits...
E85head is offline   Reply With Quote
Old 01-16-2013, 12:28 PM   #46
MKampa
My Ride: B7 Audi A4
Oh okay bud,
If we are talking basic setups then the Saad Racing kit is only $9,999.
If we are comparing stage 3, Saad Racing is still thousands cheaper than the HPf kit.
Only comparison i see is that the Saad kit is not only the best kit on the market, but also the most competitively price kit too.
Im sorry you are mislead on your information on the market but please educate yourself before posting up.
Old 01-16-2013, 12:33 PM   #47
E85head
My Ride: E46 M3
Oh okay bud,
No doubt Saad kit is very impressive!
But i don't think you get everything you need for 9.999. If so i am very interested!
Old 01-16-2013, 01:13 PM   #48
JR @ RS WORX
Past Site Sponsor
My Ride: a car
No...they are not.
Now, Saad racing stage 1 tuner system is $9,999 which is a more direct comparison. Soon to be coming with a DME tune as well. They have their shop car going together for testing as we speak and will have the final numbers SOON
The cool thing about Saad Racing is the they use the same components on the stage 1 tuner system as the stage 3 system
Stage 1 comes standard with:
3.5" stainless steel down pipe directly off the turbo with waste gate plumbed back in!
Tubular pyramid merge stainless steel manifold
4" x 7" long air filter element
Stainless steel motor mount bracket and billet aluminum engine mount
Stainless steel charge pipe from the turbo to the intercooler for durability
Gravity oil drain system
World record setting turbo system
The quality of all of their components are top notch. Garrett intercooler core, Tial bov and waste gate, Precision turbo, billet components used throughout.
No one else has these components as standard in their kits.
Recent dyno numbers put their kit at 940 hp to the tire on e85!!!
Also, the Saad Racing e85 add-on system is $750 (not $1,200) which includes the sensor, bracket, custom mandrel bent stainless steel fittings, adapter fittings for the sensor, wiring harness for the Pro EFI and Teflon braided lines. It is also adaptable to either stage1 or stage2 fuel systems
JR @ RS WORX is offline   Reply With Quote
Old 01-16-2013, 01:30 PM   #49
Commanderwiggin
So for $750 that includes the can bus display and iboost controller as well?...pretty sure that's what my 1200 estimate was including...
And a DME tune...well that'll be impressive if it's true.
Either way looking forward to seeing some of these builds come to life...can't wait till I run into one at a runway event
Old 01-16-2013, 01:59 PM   #50
SALES@RSW
My Ride: TTRS, SL65, 993
A few more pictures of product going into our build
Pauter I beam Forged Connecting Rods w/ ARP Hardware
Pauter_BMW_E46_M3_Rod_1 by Redline Speed Worx, on Flickr
Pauter_BMW_E46_M3_Rod_2 by Redline Speed Worx, on Flickr
Pauter_BMW_E46_M3_Rod_3 by Redline Speed Worx, on Flickr
Pauter_BMW_E46_M3_Rod_5 by Redline Speed Worx, on Flickr
Pauter_BMW_E46_M3_Rod_6 by Redline Speed Worx, on Flickr
Pauter_BMW_E46_M3_Rod_7 by Redline Speed Worx, on Flickr
Pauter_BMW_E46_M3_Rod_8 by Redline Speed Worx, on Flickr
.: Redline Speed Worx :. 908.223.7477
Tri-State's Premier APR Installation Center
German Automotive Repair, Performance & Fabrication
Shop Life - Click Me ! | We Complete Specialty Alignments !
SALES@RSW is offline   Reply With Quote
Old 01-16-2013, 02:00 PM   #51
JR @ RS WORX
Past Site Sponsor
My Ride: a car
You do not need those components to run e85. It's all done internally with the Pro EFI in conjunction with the sensor. You can certainly add those if you like though
Old 01-16-2013, 03:06 PM   #52
Twin_Turbo_S54
My Ride: M3
great to see other s54 turbo kits. good to see s54 platform move forward.
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 01-16-2013, 03:30 PM   #53
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
I'd have to spend some time adding components/etc together to make a direct cost comparison.. but a HPF Stage 3 includes quite a few little bells n whistles like the gauges, meth kit, etc..
The best comparison would be a HPF Stage 2.5 vs a Saad Stage 3. The difference being Flex Fuel vs Meth. Saad's flex fuel setup being significantly less than HPF's meth setup. Ignoring that though and just going Stage 2.5 vs Saad Stage 3 without doing the math I think the HPF kit is still cheaper.. and more refined.. Saad builds race cars.. and he's rather good at it.. its just hard to beat the HPF Stage anything kit as far as refinement.. and thats not a knock against Saad, or anyone for that matter.. simply put JP built an incredible turbo setup for HPF and it shows in every nut, bolt and screw..
FSR is not far behind though, after spending some time with them I'm really impressed with their attention to detail.
Source: Been there, done that.. a year and a half ago.
If you're looking for wild, and lots of custom stuff.. I'd go Saad/FSR/ProEFI.
If you're looking for an off the shelf kit that just works and can be installed by just about anyone... I'd go HPF... if you start deviating from the off the shelf setup thats where the HPF kit starts to deteriorate.
Old 01-16-2013, 03:53 PM   #54
dallasberry
My Ride: ///M3
Might also like to add that HPF also has a proven track record and a database of known problems. If you end up having a problem trouble shooting will more/less be a breeze compared to a more custom kit.
In my opinion all 4 vendors mentioned here build quality stuff, but like with everything in life they all have their good and their bad. It'll be up to what the customer wants in the end and how much they are willing to pay.
Custom Turbo Build By Lab22
815whp @ 625wtq 27psi E98
dallasberry is offline   Reply With Quote
Old 01-16-2013, 04:13 PM   #55
powerfreak1
My Ride: 04 CB/Cinn M3
Don't mean to jack the thread, but I have been looking for SAAD pricing for a while, even PM'd/Emailed the OP about it and no response. Where can I find the pricing/power outputs?
powerfreak1 is offline   Reply With Quote
Old 01-16-2013, 04:18 PM   #56
E85head
My Ride: E46 M3
There is a PDF at Saad's Facebook plage, but you need to have adding skils
Or: http://www.redlinespeedworx.com/
Old 01-16-2013, 06:14 PM   #57
JR @ RS WORX
Past Site Sponsor
My Ride: a car
I am pretty sure we responded to your're email
email me at JR@redlinespeedworx.com
Old 01-16-2013, 07:15 PM   #58
dan avoN7
My Ride: A car
If you break it down by the actual parts.. you will also notice the HPF tuner kit doesn't come with an intercooler, hot side charge piping, cold side charge piping, BOV, intake piping, intake filter, and the other big ticket items you mentioned. Also I think the comparison between the two would be the Saad Racing Stage 1 kit which is $9,999 according to this link
http://www.redlinespeedworx.com/saad...harger-system/
If you do the HPF tubular "upgrade" (yet to see results showing if this is even making more power than their cast manifold), add their intercooler, their piping, their BOV setup, their intake, etc.. you are in the same ballpark for pricing..
Kinda pointless to compare the companies other "stages" as they both accomplish their power figures through different components. HPF uses methanol to achieve higher power, thus they don't need a very extravagant fuel system (can get by with a tiny pump inline/small injectors). Saad Racing looks to E85 to achieve higher power, thus they need a much larger fuel system than stock which to do properly requires much more lines/fittings.
The other "required" pieces aren't really needed unless you are pushing the setup to the max and want it very reliable. On your car that makes 800hp+, did you change out your driveshaft, differential, add a diff brace, add flex fuel with all sensors, etc..?
If Saad is really coming out with a DME tuned setup, their Stage 1 kit would be in the same price range and offer similar components as MaxPSI's kit. I do like the fact that Saad's kit routes the intercooler piping up and over, uses a oil drain sump that appears plug/play and easily removable (MaxPSI posted a picture of their kit drain drilled/tapped in to the stock pan), etc.. Of course it would be nice to see more installed pictures of both setups to really draw a conclusion as to which kit one would go with.
dan avoN7 is offline   Reply With Quote
Old 01-16-2013, 07:21 PM   #59
dan avoN7
My Ride: A car
Something to think about.. The vast majority of these known problems/trouble shooting scenarios come from the fact that the kit is almost overly complicated when above a Stage 1. The multiple trouble shooting threads or issues are almost always related to the meth system and it's pump/sensors/lines/fittings, the oil scavenge system and it's pump/lines/fittings, etc.. This is of course my opinion (been around a lot of tuner cars over the years) but looking at MaxPSI's kit, Saad's kit, and FSR's kit.. I highly doubt you will run in to many reliability issues that require extensive trouble shooting.
Old 01-16-2013, 07:36 PM   #60
Commanderwiggin
I agree...I am against the Meth system myself and in the future will be turning it into a standard 50/50 setup for cooling but will not rely on it by any means.
