Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 01-16-2013, 09:05 PM   #61
dallasberry
My Ride: ///M3
I never said it was a simple system, just stating that most common problems are already known which in turn are easier to track down.
Custom Turbo Build By Lab22
815whp @ 625wtq 27psi E98
dallasberry is offline   Reply With Quote
Old 01-16-2013, 09:18 PM   #62
JR @ RS WORX
Past Site Sponsor
My Ride: a car
Originally Posted by Commanderwiggin View Post
I agree...I am against the Meth system myself and in the future will be turning it into a standard 50/50 setup for cooling but will not rely on it by any means.
Have you ever had any experience with Aquamist?
JR @ RS WORX is offline   Reply With Quote
Old 01-16-2013, 10:42 PM   #63
Commanderwiggin
My Ride: 900rwhp Turbo M3
The HPF system is actually very intuitive and has decent safeguards but the issue is that the HPF meth system is designed for 100% meth and the injectors pull duty so for a split second there is potential for big failure...but to answer you question no and I can't compare the two without doing some research.
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Old 01-16-2013, 11:09 PM   #64
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
I've preached since day one that the meth system was a great idea when it works, and well developed but that still doesn't remove the chance of failure.. due to all the safe guards and complexity it is a bear to troubleshoot.. and if DURING meth injection something fails its reactive.. (impossible to be proactive in a situation like that) and so for that split second.. your little 3.2l that makes 800rwhp runs lean.. and that can be JUST ENOUGH to hose something.
Old 01-16-2013, 11:26 PM   #65
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
I would like to see 50/50 mix of meth pump and water so it's non flammable and tune the car for that. ( I would worry about pooling in the intake and a manifold explosion). I would also add the AEM meth fail-safe gauge and have it trigger the low boost map if pressure drops. I would feel a lot better running it.. Since I had my AEM unlocked I'm going to make theses changes with 94 pump and see what numbers it makes.
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 01-16-2013, 11:28 PM   #66
Commanderwiggin
Not to mention the 50/50 mix is less corrosive than pure meth.
Old 01-17-2013, 08:18 AM   #67
MaverickM3
My Ride: gets badge
Saad/ProEFI stage 3 makes 940whp? Dyno? Didn't even know they had completed a stage 1 or 2 kit/setup for that matter.
MaverickM3 is offline   Reply With Quote
Old 01-17-2013, 09:01 AM   #68
JR @ RS WORX
Past Site Sponsor
My Ride: a car
Jasons old car made 940whp.
Old 01-17-2013, 09:20 AM   #69
Sound Performance
Past Site Sponsor
Location: Well, Dick, here's the deal: I'm the best there is, plain and simple. I mean, I wake up in the morning and I piss excellence. You know, nobody can hang with my stuff.
My Ride: Is very FAST
Perhaps the Saad Racing kit is a bit more expensive than the other available kits but it has been proven to make the most HP. Just look at the trap speeds the cars run in the 1/4 mile. They are 10+ mph than any other cars out there even the HPF orange car! Gotta pay to play guys!
Sound Performance is offline   Reply With Quote
Old 01-17-2013, 10:54 AM   #70
garrett2r2taz
My Ride: the bus
Saad Racing stage 1 kit is 9999.99 But the pre rec. is as of "RIGHT NOW" you need a pro-efi which go from 2700-3600, stage 1 does not include a new intake, you can get the stage 2 the only difference is the intake manifold,i Have talked to saad and they currently are working on a DME tune working with jason at pro-efi to try and make the best DME tune.
garrett2r2taz is offline   Reply With Quote
Old 01-18-2013, 02:50 AM   #71
MarcusLSB
On the 6766? With or W/O the bottle? I'm sure it did.. but with what configuration?
Old 01-18-2013, 05:58 AM   #72
M5chas
My Ride: e90 m3 + cornfed gtr
I never got a straight answer out of Jason regarding the hp numbers on his car, not that #s were needed, as its trap speed obviously backed up any number that might be needed. When I owned it, Garth at Undercover Performance tuned it and it made 890whp on a mustang.
M5chas is offline   Reply With Quote
Old 01-18-2013, 09:19 AM   #73
JR @ RS WORX
Past Site Sponsor
My Ride: a car
It made 940whp without spray.
Then made 1060whp with spray
all on the 6766
Old 01-18-2013, 09:20 AM   #74
JR @ RS WORX
Past Site Sponsor
My Ride: a car
When did you sell it?
Old 01-18-2013, 04:37 PM   #75
323tom
My Ride: 2 turbo e46's
1060 whp?! Really with a 6766 and how much spray? Does Jason's old car have a tubular manifold? Also he always dynos on a dynojet correct?
all on the 6766
323tom is offline   Reply With Quote
Old 01-18-2013, 04:47 PM   #76
E85head
My Ride: E46 M3
Have you had yours on the dyno again?
E85head is offline   Reply With Quote
Old 01-18-2013, 05:17 PM   #77
323tom
Not yet, still patiently waiting for sound performance to put the FSR tubular mani on my car and see what it's capable of
Old 01-18-2013, 05:28 PM   #78
Commanderwiggin
At this rate winter will be over before then
Old 01-18-2013, 05:50 PM   #79
Saad @ Saad Racing
Past Site Sponsor
My Ride: S600
Jason's car had a prototype Saad Racing tubular exhaust manifold. The new design is much better than the old and the old one was the best at the time it was made.
Saad @ Saad Racing is offline   Reply With Quote
Old 02-03-2013, 06:23 AM   #80
E85head
My Ride: E46 M3
Project status:
