E46 Xi Forum
Old 01-09-2013, 03:07 PM   #1
pinoyboy204
My Ride: 2003 BMW 325XI
Clutch pedal clicks when depressed
As the title says. When I press on the clutch there seems to be some kind of click noise and can be felt when pedal is pressed, it does not happen all the time . What can be the problem?? Is it a bushing of some sort?
pinoyboy204 is offline   Reply With Quote
Old 01-10-2013, 09:26 AM   #2
Newman513
My Ride: 325xiT Hellrot 5spd
It may be the switch that actually doesn't allow the car to start unless the clutch pedel is depressed.
Get in the car, and press the pedel down, but stop before you hear the click, and try and start the car. It should not start if you haven't heard this click.
Now try again, but this time depress the clutch, and as soon as you hear the click, try to start the key. If it starts this time then it's just the button that you're hearing.
Newman513 is offline   Reply With Quote
Old 01-10-2013, 06:39 PM   #3
SamDoe1
My Ride: 4cyl of fury
^ This. It's the clutch relay most likely. You shouldn't be able to hear it and certainly shouldn't be able to feel that though...
