///M3 Forum
Old 01-10-2013, 01:01 AM   #1
Westrace
My Ride: 06 G35, 04 M3 Coupe
Part number for AC belt tension pulley
Which one of these is the tension pulley on for the AC belt? I see two pulleys -- one idler and one tension pulley for the main serpentine belt -- but I can't see which one for used for the AC belt?
Edit: I think it's #13. I am not sure why it costs so much though.
Westrace is offline   Reply With Quote
Old 01-10-2013, 04:21 AM   #2
M3Nick
RACECAR Backwrds Is RACECAR
My Ride: '06 M3 ZCP, Cayman-S
According to other threads, it is Dayco 89133
http://forum.e46fanatics.com/signaturepics/sigpic79554_2.gif
M. THE MOST POWERFUL LETTER IN THE WORLD.
M3Nick is offline   Reply With Quote
Old 01-10-2013, 08:41 AM   #3
Charmervin
My Ride: 2001 325ci
You are correct in assuming it's #13...and you should check ..., realoem, pelicanparts among other sites that have very good prices... I just replaced my tensioner that drives the water pump, alternator, powersteering etc for $48.95... And that's not expensive at all...
Charmervin is offline   Reply With Quote
Old 01-10-2013, 08:49 AM   #4
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
OP, you need to know if you have hydraulic or mechanical tensioner. #13 shows mechanical tensioner with pulley...but that's no longer a bmw part...it's shifted to all hydraulic now.
I just replaced my pulley...and although many are mechanical tensioners and take the 89133 pulley, some are hydraulic. You need to look and know what you have...or just order both and return the one you don't need.
See threads with 'pulleys' in the title...you'll learn all you need to know.
Of course, do the belts...and of course, do all three pulleys...since when one is gone, the others are close behind.
See me in June!
dmax on Facebook
Mangofy your E46!
Old 01-10-2013, 10:02 AM   #5
S54Dan
My Ride: '05 M3 '03 ZHP
OEM part # 11281433571
2005 M3 6MT | Weekend toy & Track rat
2003 330i ZHP 6MT | Wife Mobile
1994 325i 5MT | DD
Instagram @S54Dan
S54Dan is offline   Reply With Quote
Old 01-10-2013, 10:13 AM   #6
Westrace
My main belt tension pulley is hydraulic but I think the one on the AC belt has always been mechanical I think. I notice the cost does vary from vendor to vendor. Tischer has it for $99 while ECS Tunnings about $67. I'll be doing my water heater and will replace the pulleys on the main belt, but I think I'll wait on this one. When I spin it, it seems pretty quiet - no noise. Worse comes to worse, I'll be driving without the AC :-).
Here's my part list:
Mechanical Catalog - 2004 - BMW - M3
cooling system, thermostat M3 $44.39 $8.88 $35.51 $0.00 $35.51 Delete From Cart
Collision Catalog - 2004 - BMW - M3
cooling system, cooling, water pump, water pump assy M3 $499.42 $99.88 $399.54 $0.00 $399.54 Delete From Cart
cooling system, cooling, water pump, water pump assy gasket M3 $8.84 $1.77 $7.07 $0.00 $7.07 Delete From Cart
cooling system, cooling, water pump, thermostat gasket M3 $4.74 $0.95 $3.79 $0.00 $3.79 Delete From Cart
OEM Catalog
O-RING $1.87 $0.37 $1.50 $0.00 $3.00 Delete From Cart
OEM Catalog
O-RING $2.16 $0.43 $1.73 $0.00 $1.73 Delete From Cart
cooling system, cooling, belts & pulleys, tension pulley HYDRAULIC TENSIONER, adjust $50.59 $10.12 $40.47 $0.00 $40.47 Delete From Cart
Collision Catalog - 2006 - BMW - M3
cooling system, cooling, belts & pulleys, tension pulley HYDRAULIC TENSIONER, idler $49.63 $9.93 $39.70 $0.00 $39.70 Delete From Cart
Old 01-10-2013, 12:05 PM   #7
S54Dan
ECS tuning is cheaper because the part is not OE
PS: E46 M3 always use mechnical AC tensioner. It's only the Non-m that it changes
1994 325i 5MT | DD
Instagram @S54Dan
Old 01-13-2013, 08:50 PM   #8
Westrace
Does turning the fan nut mess up the engine timing? It took me a few tryiniesg - having to turn the nut may be two or three times to be able to get the fan nut off.
Initially I was trying to hold down the screw then tried to turn the 32mm wrench but couldn't find a good way to pivot. Finally I had to do a couple of whack on the wrench
and surprisingly the nut came off pretty easily.
When you turn the water pump, the entire engine also turn right? So does it anyway mess up the engine timing?
