Old 01-10-2013, 02:20 AM   #1
2000 323
My Ride: 323ci
Newbie cluster problem
Hey guys new to BMW's , just picked a clean weekend car 2000 323Ci coupe 5 spd 2.5, It runs and drives amazing i love it. Only problem is that none of the needles/gauges work on my car. The bottle digital gauge with the miles,temp,distance, and oil change life still work just not the mph/rpm/gas/temp. now Ive tried doing the holding the buttton in and "resetting" the cluster but none of them move when i do the reset, so I've ruled it down to the cluster its self. checked all the fuses and and the wiring is all good. Now my MAIN question is can it be anything else? And I've read you can buy a used cluster and it will work and not need to be programmed but if the miles are lower you will get a tamper light! But my question is if you out a cluster with higher miles will it work? And have no tamper light ? thanks for any input!
2000 323 is offline   Reply With Quote
Old 01-14-2013, 10:31 PM   #2
2000 323
My Ride: 323ci
No one has answers to this
Old 01-15-2013, 12:40 AM   #3
daniel_f.
My Ride: 330iC
you will always get the dot. you canīt change the vin and the odometer with bmw utilities.
Old 01-22-2013, 07:33 AM   #4
NukeMiller
My Ride: 2005 325i
Should have no problem getting a new cluster without getting a tamper light...just ask BMW service....pretty sure all you do is reset the cluster after installing new one. There is a reason you can buy new ones with no issue from dealer
NukeMiller is offline   Reply With Quote
Old 01-22-2013, 02:11 PM   #5
2000 323
My Ride: 323ci
It's 880$ don't want to spend that much, want to keep it under 200
Old 02-06-2013, 07:55 PM   #6
NukeMiller
My Ride: 2005 325i
I get that...just saying that you should be able to buy a used cluster and it should have no problem reading out to what your proper milage is....if it didn't, crooked dealerships would use this tactic left and right to increase the price of thier cars
