Sponsored by The Tire Rack
Old 01-10-2013, 02:27 AM   #1
eson
My Ride: E46 M3, Porsche 911
E46 M3 Squared Setup
I've got a pretty damn low E46 M3 sitting on Bilstein PSS9 coilovers and recently picked up an extra set of wheels for basically free. So now I've got a total of four rear wheels, which gave me an idea...
I know you may need specifics, but as an educated guess - Would I be able to run two rear OEM M3 18s up front with a 255 or 265 tire without fender modification?
Here's a picture for reference..
UPDATED QUESTION: I plan on ordering some 18" VMRs or Apex ARC-8s in the next few months and wondering as a rough estimate - What width and most importantly offset should I be ordering/running with my setup above? I would like it to be as aggressive as possible without any fender modification whatsoever. Thanks!
Name:	Adrian's racing pixs 20OCT2012 021.jpg
| '02 LSB slicktop ///M |
StopTech. SGT. AKG. TMS. BimmerWorld. Sparco. Kirk. RE. Enkei. Meisterschaft.
eson is offline   Reply With Quote
Old 01-10-2013, 10:17 PM   #2
eson
Update: It slightly rubs on the plastic inner fender lining when the wheel is fully turned either way.
Would this pose a problem or will it work itself out by shaving away the necessary plastic? Or will that damage the tire?
Thanks in advance
Old 01-11-2013, 08:37 AM   #3
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
I would proactively shave the plastic off using a dremel or other tool rather than let the tire do it. The friction of letting the tire do it may cause excess heat buildup.
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
Old 01-11-2013, 02:09 PM   #4
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Agreed.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 01-21-2013, 02:28 AM   #5
eson
Bump for another question - I plan on ordering some 18" VMRs or Apex ARC-8s in the next few months and wondering as a rough estimate - What width and most importantly offset should I be ordering/running with my setup above? I would like it to be as aggressive as possible without any fender modification whatsoever. Thanks!
Old 01-22-2013, 10:42 PM   #6
eson
Bump
