Old 01-22-2013, 07:11 AM   #1
Julioalberto236
My Ride: BMW E46 328i 1999
100LL fuel
Goodmorning everyone. I have a E46 328i 1999 with about 136,200 miles... I currently moved to a new state and since im a pilot i have easy access to this type of aviation fuel "100LL"... I would like to know if its ok to use it in my car and if doesnt what problems may it cause, note: i wont fill up the tank with this fuel, ill only use a 20onz bottle now and then but still would like to know the consequences on that.. Thank you
Julioalberto236 is offline   Reply With Quote
Old 01-22-2013, 07:34 AM   #2
Foxtrot_Uniform
My Ride: 325Xi
A 20oz bottle won't do anything for you and a tankful will burn your valves out. (If you use it over and over.)
I used to work at an airport as a kid. The owner always got pissed when we ran out of regular gas and put 100LL into the riding mower. The AvGas burned out so many engines that he eventually put a sign up where we parked the mower. NO 100LL in MOWER!
I used to mix it half and half with regular gas with my old musclecar... But that was back in the late 70's... I don't think I would try it on your BMW... Just sayin'
Foxtrot_Uniform is offline   Reply With Quote
Old 01-22-2013, 07:35 AM   #3
Jesse M
My Ride: 05' ZHP
No, you need premium UNLEADED fuel.
Jesse M is offline   Reply With Quote
Old 01-22-2013, 07:38 AM   #4
Foxtrot_Uniform
My Ride: 325Xi
Excellent point...
Old 01-22-2013, 07:45 AM   #5
Julioalberto236
Thanks for the heads up
Old 01-22-2013, 07:47 AM   #6
HiHoBrian
My Ride: 05 M3
The lead can foul your cat converter and damage the O2 sensors. Causing it to run worse,and actually burn the cat up fairly quickly. I believe Bmw DMEs can adapt up to 100 octane but it must be unleaded.
sent from my ATARI sc1224
HiHoBrian is offline   Reply With Quote
