Go Back   E46Fanatics > New Member Introductions
New members check-in, introduce yourselves, and post a picture of your BMW here!
Old 01-16-2013, 12:29 AM   #21
Nickvjr
My Ride: 2004 330Ci Conv.
Send a message via AIM to Nickvjr Send a message via Yahoo to Nickvjr
Welcome OP! Once you get your PM all caught up then you can add some modifications to your E46 (angle eyes, suspension, etc.). Also doing some coding will also enable built in features of your E46. Have fun!
-Nickvjr
2004 BMW 330Ci Convertible
Nickvjr is offline   Reply With Quote
Old 01-16-2013, 12:34 AM   #22
Jsmk23
My Ride: 02 325i-JapanRot Red
PM?
Yeah I want to add angel eyes for sure. DO you know it they are easy to put on?
Jsmk23 is offline   Reply With Quote
Old 01-16-2013, 06:31 PM   #23
rg1bmw
My Ride: 2002 Infiniti Q45
Welcome
2002 BMW 530i
Black Leather/5 Speed/Sport Package
rg1bmw is offline   Reply With Quote
Old 01-16-2013, 09:32 PM   #24
Jsmk23
Originally Posted by rg1bmw View Post
Welcome
Thank You
Old 01-23-2013, 06:36 AM   #25
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
welcome
/_________\
O==[][]==O
Old 02-02-2013, 03:07 PM   #26
Jsmk23
I have a question for you guys. There's a whistling/rubbing noise coming from engine when I start it up. The noise gets louder as I accelerate but goes away after 5-10 of driving.
It usually does this from a cold start up.
Also, I tried to listen if it's coming from the pulleys but it sounds like it's coming from more in the middle of the engine.
Old 02-02-2013, 09:11 PM   #27
Polodown
My Ride: 2000 BMW 323Ci
Does the radiator fan have any wobble to it? Could be the water pump, the impellers are plastic and get brittle with age. This happened with my 2000 323Ci and caused a similar noise.
Polodown is offline   Reply With Quote
Old 02-02-2013, 09:21 PM   #28
Jsmk23
No the fan looked stable in place, no wobble at all.
Old 02-04-2013, 11:38 AM   #29
J.Khlok
My Ride: 2003 M5, 2007 335i
looks good, plenty of potential
2003 E39 Carbon Black M5
Euro.Techniks
J.Khlok is offline   Reply With Quote
Old 02-04-2013, 02:27 PM   #30
Jsmk23
Thank you!
Old 03-22-2013, 11:40 PM   #31
Jsmk23
Bad news today fellow fanatics.
Driving up the interstate with my normal every 2 weekends drive from San Diego to Palm Springs, within 30 mins on the freeway, I noticed my battery light came on my dash.
First time I ever seen this.
After 5-10 mins from when I started driving I noticed my temperate needle went up fast.
I pulled over when it went up, and when I went to lift up the hood there was no smoke.
So I went back in the car to start it up and I noticed my steering wheel was tough to turn. So I figured it was my power steering pump.
When I checked under the car it was dripping slowly.
So I just called my roadside assistance to tow it back to a shop.
So I was wondering if you guys could give me a heads up on what it could be more or less besides that the shop could charge me a fortune.
Thanks.
Old 03-23-2013, 02:11 PM   #32
///MPR77
My Ride: 02 ///M3 Tri-Ped
Sounds like your serpentine belt, or a pulley broke...perhaps both.
The serpentine is running the: PS, Water Pump, Alternator.
Without the belt, you have no Power Steering, no coolant circulation, and no charge on the battery.
Where was the leak coming from?
How long did you drive it hot?
Do you have tools, and are you good at following directions?
This is a very easy fix, that could be done by a rookie in a few hours.
Report back, when it gets diagnosed.
Old 03-23-2013, 02:35 PM   #33
Jsmk23
I couldn't see where the leak was coming from cuz I was stuck on the expresslane.
But it was leaking a green liquid.
I pulled over right when it got hot.
So I turned it off. Turned it back on, and it was still on, but I had to drive to the nearest exit which was about half a mile away.
Yeah I have tools but not a place to work on it cuz I just moved to an apartment complex.
How long would this fix take?
Old 03-23-2013, 03:18 PM   #34
///MPR77
Is your car Auto, or Manual?
The Automatic uses a different Fan, and could add a bit of time to the job, there is a special fan clutch tool, however I have read that it isn't necessary, and can be substituted for a long flathead screwdriver, but I have a manual, with an electronically controlled fan, so I can't say for sure.
Red Flag on the "green" coolant leak, of course the fact that it is leaking is bad, but the fact that it is green, says that the last person to top off the coolant used the wrong coolant.
Not that this was the source of your problem, but many people including myself are vehemently against the green stuff. (Only Genuine BMW/Mini coolant) its a couple bucks more expensive to use the prescribed stuff, and a couple dollars for distilled water (only)
If one pulley went bad, you can assume the others are not far behind.
I would replace all them, to keep you from having to revisit this job prematurely.
Now, for the cooling leak....let me just ask, do you know the cars service history...specifically the cooling system?
If you're not sure, I would replace everything, except the hard pipes, and radiator, unless of course they are leaking.. unlikely that they are.
If you are well prepared: read/print the DIYs, and have tools, and all the parts...you could knock out everything cooling system, and pulleys in 4-5 hours, as a first timer on this car. Its about a 2 hour job for me.
Old 03-23-2013, 03:21 PM   #35
///MPR77
Links:
http://forum.e46fanatics.com/showthr...st/bleeding) *
http://forum.e46fanatics.com/showthr...leys you need)
Old 03-23-2013, 03:47 PM   #36
silverbullet3
My Ride: 06vert
Awesome ride and welcome. I'm new too. Just got my new girl and am very excited to get started on her. Had a few scuffs on the bumper I had taken out as my first investment. My first 3 was a red 325. Nice.
ID:	496712   Click image for larger version
silverbullet3 is offline   Reply With Quote
Old 03-23-2013, 04:14 PM   #37
Jsmk23
Thank you.
Ill inform you once I get word from the mechanics since its at the shop.
Old 03-23-2013, 06:56 PM   #38
Jsmk23
It turned out to be:
-Radiator reservoir
-tensioner pulley
-idler pulley
-serpentine belt
They wanna charge me 575$
Is that too much?
Or is it easy enough to do it by myself. ?
Old 03-23-2013, 07:03 PM   #39
HBizzo88
My Ride: 2002 bmw 330ci
-Radiator reservoir
-tensioner pulley
-idler pulley
-serpentine belt
Is that too much?
It's cake. Nothing worth spend $600 on.
HBizzo88 is offline   Reply With Quote
Old 03-23-2013, 07:09 PM   #40
Jsmk23
Any links?
Display Modes
