How about for someone that's never done this before so I'd be following instructions while doing the repair work. Also, can this be done with a simple jack one wheel at a time? I'm thinking about searching for afterhours mechanics vs. DIY but if I do it myself, then I'd have to make sure I have all the tools and extra parts in order. Do you think an afterhours mechanic (say from Craigslist) can do all four wheels (just pads and sensors, not rotors) for say 2 hours labor? Thanks again for the replies.
I was thinking shop procedure. Yes it can be done with a single jack one wheel at a time but I wouldn't do this job using your car's jack. Its too unsteady. You will need a trolley jack for safety reasons. I would also advise using an axle stand, or some bricks or a block of wood, as a backup to the jack just in case but its not essential. As for the actual pad changing you might conceivably make it half hour per wheel allowing for a more cautious approach and following instructions. You might even do front one day and the rear another day but you must do both fronts together and both rears together otherwise you will have uneven braking either side. So plan the job, check out the link below. The rears are the same process just smaller pads.
Yes and yes.
This is one of those things where its just too easy to NOT do yourself.
There are literally just a couple bolts which need to be undone on the caliper.
A local sponsor had OEM-spec brake pads for $20/set rear, $35/set front.
You need to do 30% of the work shown in this video, since you're only changing pads:
Yes and yes.
Curious. Did you not notice the comment and video immediately above yours?
