///M3 Forum
Old 01-11-2013, 05:27 AM   #1
iamwilliam
My Ride: 04 m3 coupe
Angry HELP! New alternator and battery but car charges intermittently
Had the battery light start flickering on and off for a few days so i ran the obc test and found that the voltages to be 11.3v when off and at 11.8v when on. After spending hours on the forums I came to the conclusion that it was the alternator. This car is my dd so i needed one asap and an o'reilly in the area had one (ultima reman), i picked up the alternator and a new battery (bosch 49r) since my battery was 7 years old. Slapped both parts on and fired it up, 12.6v off and 14.5v on. Drove on it for 2 days and everything was perfect then on the way to work the battery light comes back on and the voltages are wacky again. I drove home with the obc on and the volts would drop as low as 9.5v and then out of no where up to 13.6v. What the heck is going on? I'm ready to throw in the towel and take the car in, unless any of you car gurus has any idea. Any help is much appreciated. Thanks in advance.
iamwilliam is offline   Reply With Quote
Old 01-11-2013, 10:41 AM   #2
joeysm3
My Ride: ///M3 02
check the belts when they wear off, they start slipping giving less voltage. happened before at my dads shop. goodluck
joeysm3 is offline   Reply With Quote
Old 01-11-2013, 11:21 AM   #3
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Check all your alternator and battery connections.
Verify voltage from the battery all the away to the alternator.
BMWCaptain is offline   Reply With Quote
Old 01-11-2013, 02:01 PM   #4
iamwilliam
Do I check the voltage when car is off? Or running?
Old 01-11-2013, 02:14 PM   #5
BMWCaptain
Check it with the car off. You want to see if your loosing you voltage across a connection or wire.
Some folks have had a bad connection in the trunk positive wire that runs to the front +B terminal.
Old 01-11-2013, 07:11 PM   #6
iamwilliam
Ok thanks I will check that first.. I've also heard of a bad ground somewhere, any ideas where the common fault points are?
Old 01-12-2013, 12:57 AM   #7
iamwilliam
I checked the battery voltage, under the hood +B terminal voltage, and alternator voltage. All read the exact same readings. Did I receive another faulty alternator?
Old 01-12-2013, 02:56 PM   #8
iamwilliam
Ttt
Old 01-12-2013, 08:38 PM   #9
iamwilliam
Had original alternator and the ultimate reman tested and both failed so I've learned my lesson and will never buy a crap reman alternator again. Oem valeo is being rebuilt by a reputable auto electronic shop in the area. Hope this works out.
