Old 01-11-2013, 10:14 PM   #1
cw18306
My Ride: 01 BMW 325Ci Vert
2001 e46 325Ci Convertible ODBII Codes...Help Please.
I have a 2001 325Ci/vert. automatic with 125K miles. Last year, I had to have the oil separator/vent valve replaced. Several months later my CES light came on. It has been running pretty well. The only issue I have is, when I floor it, I doesn't have the torque it use to. And the rpm needle will go into the red if I don't let off the gas some. I replaced the MAF with a Seimins MAF a few years ago prior to the vent valve repair. That was close to $1000
Here are the codes I got from Autozone. Any help determining what to do will be appreciated.
P0015: Camshaft position timing over - retarded bank 1.
P0102: Mass or Volume Air Flow Circuit low Input.
P0172: System too rich (Bank 1)
P0175: System too rich (Bank 2)
P0313: Mis-fire with low fuel.
cw18306 is offline   Reply With Quote
Old 01-11-2013, 11:28 PM   #2
wildirish317
My Ride: 2004 325Ci vert
First guess would be the fuel filter. How long since that's been changed?
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 01-12-2013, 12:22 AM   #3
Guest021715
Account closed.
First thing to do is unplug your MAF sensor and see if the problem persists.
Old 01-12-2013, 12:45 AM   #4
cw18306
I bought it used back in 2009. Never replaced it. I have put about 35K miles on it. How often should the fuel filter be replaced?
Old 01-12-2013, 12:48 AM   #5
cw18306
I unplugged the MAF sensor earlier only in park at idle. The idle dropped ever so slightly, but noticable. Didn't take it for a spin though.
Old 01-13-2013, 03:43 AM   #6
cw18306
OK, I tried disconnecting the MAF sensor again while the car was running and it cut off right away. Thinking maybe replacing the fuel filter will do the trick?
Old 01-13-2013, 02:05 PM   #7
Guest021715
Account closed.
It wouldn't hurt to change the filter, but I doubt that is the problem.
With the car off, disconnect the MAF. Start the car.
Since its an automatic, it my go into limp mode -but pay attention to how the engine runs.
The MAF can cause all of those codes you posted.
