Affordable Inspection II for Texas residents. - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Southwest
Southwest
AZ NM NV OK TX UT
Old 02-25-2013, 02:11 PM   #1
M Shark
My Ride: '04 M3
I just had my inspection II done at our local BMW dealer here in McAllen Texas and the total I got for the service is $1298.13
If you are from San Antonio, Houston, Corpus Christi or even Dallas area you might want to give them a call to save about $1000. I called 1 BMW dealer in San Antonio and Houston and they both quoted over $2400 for the Inspection II. Valve adjustment wasn't needed as they were still within spec, FCAB & RTAB are still in good shape, and as requested, I asked them if they could check for any subframe damage and they said it's not included but they could have a good look around without taking down the suspension. I also asked them if it's possible to check the Vanos but they stated if they don't find any triggers in the diagnosis there would be no need to open up the engine to check the condition of the Vanos assembly.
it sucks knowing that the only work they had to do was something I could have done DIY style but I don't have the time to do it with my current job.
Here's a copy of the Job Order
_____________________________________________
M Shark is offline   Reply With Quote
Old 02-26-2013, 09:32 PM   #2
Mr. Din
My Ride: e46 M
so how did they know the valves were in spec?
[/URL]
Mr. Din is offline   Reply With Quote
Old 02-26-2013, 10:34 PM   #3
bigugly
My Ride: things that go fast.
All my inspection II's get a Vanos hub check(visual), bolt check (the 10's in front), valves adjusted correctly, and for 35 bucks extra....an oil analysis.
I can murder that price, btw.....especially when you want to do a dr. Vanos assembly and hub/bolt repair/replacement/preventative maintenance.
fabrication is meditation
the only thing I can't fix is broken hearts.
https://www.facebook.com/BMWdoctor
I want to be your BMW products' authorized installation center in Houston.
bigugly is offline   Reply With Quote
Old 02-26-2013, 10:42 PM   #4
Bemwe_03i
My Ride: 2003.5 E46 M3 smg IR
fuel additive? Anyone here add the lucas fuel treatment to their m3's? 5-6oz per fuel tank.
some of those things you can easily do your self or take off from the list wiper blades really? even spark plugs easy to do...cost around 60$ for 6
...ps right you dont have time just saw that
Bemwe_03i is offline   Reply With Quote
Old 02-27-2013, 12:10 AM   #5
AlpinTXiX
My Ride: 03 M3
For SA (and maybe Austin) folks I just got my Insp II done at Rhine West...cost me $1400 but some of that was extra because there was some gunk build up around my valves which required extra work to remove. I wouldn't recommend driving all the way down to McCallen unless you have a place to stay and or car to drive back in, as gas and potentially hotel while you wait for the car to get done will likely set you back any $$ you save.
AlpinTXiX is offline   Reply With Quote
Old 02-27-2013, 09:02 AM   #6
Adionik
My Ride: Bavarian Panzer
You can do 99% of Inspection II yourself for 1/5th of that...i'm stunned at the prices quoted
Adionik is offline   Reply With Quote
Old 02-27-2013, 02:55 PM   #7
AlpinTXiX
My Ride: 03 M3
Not everyone has the time (or maybe facilities or mechanical know how) to do it themselves. That's why shops exist and I think the point of the thread is to point some of the better ones in the area
