Old 01-12-2013, 03:50 PM   #1
jpbutler1983
My Ride: 2001 325Ci
Stranded. Please help.
Car won't turnover. Makes the noise, cranks then fizzles out...
Fuel? Flooded?
A man will be the same with a title as he was without one
jpbutler1983 is offline   Reply With Quote
Old 01-12-2013, 03:56 PM   #2
AmazingNutz
Banned User
My Ride: carpet
I'd start with a jumpstart, check loose connections and battery.
Sent from my G6
AmazingNutz is offline   Reply With Quote
Old 01-12-2013, 04:00 PM   #3
jpbutler1983
My Ride: 2001 325Ci
But it doesn't seem to be an issue with voltage. It doesn't sound like a dying battery. It sounds like it is not getting what it needs to finish the turnover...
Old 01-12-2013, 04:02 PM   #4
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
My Ride: Project 330xi
It still could be the battery. It's the easiest to diagnose so you might as well investigate it. I'd first try to jump it.
-Gary
DiscoStu is offline   Reply With Quote
Old 01-12-2013, 04:24 PM   #5
jpbutler1983
My Ride: 2001 325Ci
I don't t think it's a battery issue... But it's an easy check so...
Old 01-12-2013, 04:26 PM   #6
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
There should be positive and negative terminals under the hood. Look up in the top left corner. You can also access the battery directly in the trunk on the right side.
-Gary
Old 01-12-2013, 04:26 PM   #7
jpbutler1983
My Ride: 2001 325Ci
ID:	485771 negative lead.
Old 01-12-2013, 04:27 PM   #8
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
Yes
-Gary
Old 01-12-2013, 04:28 PM   #9
jpbutler1983
My Ride: 2001 325Ci
Thanks. I've just heard so many horror stories about electronics going haywire after a jump
Old 01-12-2013, 04:28 PM   #10
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
If you're asking us about fuel, maybe you should add fuel...especially if you're showing less than 1/4 tank. The gauge often fails.
If you hear a strong cranking...it could just be fuel...could be fuel pump (rarely is FP relay or fuse, but you can check fuse and if you want, swap horn and FP relay).
Use cluster test for voltage...s/b around 12 off and around 14 when on.
The negative terminal under the hood is just behind the +terminal inside the drug bin...on the other side of the partition...same nut as on +terminal.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 01-12-2013, 04:30 PM   #11
jpbutler1983
My Ride: 2001 325Ci
I have 3/4 of a tank.
I was referring to the pump. I checked the fuse. Its fine. I haven't checked the schrader valve under the hood cover to see if it sprays fuel because I have no tools in this parking lot
Old 01-12-2013, 04:32 PM   #12
jpbutler1983
My Ride: 2001 325Ci
I just filled up yesterday with 93 unleaded from BP. Driving fine the whole time. Went in a store today, came out, and now this
Old 01-12-2013, 04:34 PM   #13
jpbutler1983
My Ride: 2001 325Ci
I did go through a carwash with an undercarriage wash... ?
Old 01-12-2013, 04:45 PM   #14
jpbutler1983
My Ride: 2001 325Ci
There are two fuses for the horn 5a and 15a... The fuel pump fuse is 20a
Old 01-12-2013, 04:57 PM   #15
dmax
dmax's Avatar
You can check your Kalim fuse...the 20 amp fuse in the fuse pack in the e-box...black box in front of driver under hood. That fuse going will also lead to a no start as it feeds the FP relay power...iirc
Mangofy your E46!
Old 01-12-2013, 05:04 PM   #16
jpbutler1983
My Ride: 2001 325Ci
Well I checked the fuel valve under the hood cover, fuel sprayed. Got a jump with no change in symptoms.
Old 01-12-2013, 05:24 PM   #17
AmazingNutz
Banned User
My Ride: carpet
OP, how old is your battery?
Sent from my G6
Old 01-12-2013, 05:30 PM   #18
Blueandwhite85
My Ride: E46
Mileage? I'm going to go with fuel pump if there were zero issues before this happened. On the rear passenger side of the car right at the wheel, you should be able to hear the fuel pump buzz a bit. Will need someone to turn the key from position 0-2 while you listen though.. if you don't hear anything at all... bing bing bing. Happened to my e46, my neighbor's and also a friend's.
Blueandwhite85 is offline   Reply With Quote
Old 01-12-2013, 05:56 PM   #19
dmax
dmax's Avatar
Hmmm? I believe the system stays under pressure, so not sure that's 100% that FP is okay.
Buehler?
Mangofy your E46!
Old 01-12-2013, 05:58 PM   #20
BimmersGarage
My Ride: E46 330i
OP,
If you get a jump from someone with vehicle that has a small* battery it will not be enough to jumpstart your bimmer.
*You need at least 740 CCA battery to properly jump.
BimmersGarage is offline   Reply With Quote
