Old 01-12-2013, 08:23 PM   #41
monkeyhead
My Ride: 2003 330i
not sure what battery u might have, but to test and recondition certain batteries
see one, do one, teach one
monkeyhead is offline   Reply With Quote
Old 01-12-2013, 08:24 PM   #42
jfoj
My Ride: 330CiC, M5, X5, E93
1. Starting fluid, if the engine starts and dies, then you have 100% confirmed you have a fuel delivery issue.
2. You need to read this link, http://forum.e46fanatics.com/showthread.php?t=929501 since you are using a mobile app you cannot see my signature.
3. Does not matter how good you are with a Voltmeter, you WILL get lost. It has to do with the way the BMW circuitry for the fuel pump works. You will see a constant 5 Volts or something close to that at the fuel pump connector, then chase your tail. Order a fuel pump, suggest you do it directly via BMAParts.com. They are in CA, however, in VA I received my package the next day. The label showed BMA in CA as the source, but I went in and checked the UPS tracking info and it came from PA or DE, so this is why I had it the next day even though it was UPS ground.
I would be careful about the cheaper BMA pump on Ebay. BMA has multiple suppliers they use, most here go with the Siemens/VDO pump as I recall?
It is around $125 with the SpecE30 discount code.
If you need to get the car started, might be able to bang on bottom of tank or top of pump to jar the commutator to get the pump started for a drive??
Old 01-12-2013, 08:32 PM   #43
jpbutler1983
My Ride: 2001 325Ci
I don't see a fuel pump relay fuse... All I see are all the listed fuses on the diagram and the only one pertaining to fuel is the fuel pump fuse, not a fuel pump relay fuse... and I don't see any relays BEHIND the glove box... any guidance or pictures would be helpful. thank you.
A man will be the same with a title as he was without one
jpbutler1983 is offline   Reply With Quote
Old 01-12-2013, 08:37 PM   #44
sfcjetjr
My Ride: 2002 BMW 325i
I never hear my pump in or out of the car.
sfcjetjr is offline   Reply With Quote
Old 01-12-2013, 08:40 PM   #45
jpbutler1983
My Ride: 2001 325Ci
THAT sir was a freakin awesome write up. I will definitely do as you recommend. It's a 2001 and I had it for almost 3 years I think. don't have any maintenance records from previous ownership. sounds great. i will go ahead and replace all three as a CM/PM effort. I thank you for your input. Awesome.
Any special instructions on filter replacement. Or will the normal instructions for most any car suffice. I have a collar set for inserting on the fuel line to assist with removal... can I use those?
Old 01-12-2013, 08:42 PM   #46
jfoj
2001 car, trust me, 90%+ chance its the pump, even if it not the pump at this moment, your car needs a fuel pump.
You have to removed the glove box door and the glove box liner to get to the relays, I think there are 5 in there as I recall?
You will be happy once the pump is replaced!
Old 01-12-2013, 08:46 PM   #47
jfoj
Fuel pump has standard worm drive clamps or you will need standard worm drive clamp as the current ones may be crimp style??
Check the fuel pressure regulator vacuum hose as well, this breaks and causes vacuum leaks and CEL to come on.
While you are waiting and ordering parts, you might want to read this for entertainment! http://forum.e46fanatics.com/showthread.php?t=897616
Old 01-12-2013, 08:47 PM   #48
jpbutler1983
My Ride: 2001 325Ci
After reading your write up, it dawned on me that just the other day, it seemed like my acceleration had been declining in vigor lately... so, I will just do this. Even if it doesn't fix the problem (which i am sure that it will), it will be done
Old 01-12-2013, 08:48 PM   #49
jpbutler1983
My Ride: 2001 325Ci
Then it might need replacing!!
Old 01-12-2013, 08:52 PM   #50
jpbutler1983
My Ride: 2001 325Ci
Holy crap man. You basically wrote a freakin book!
Old 01-12-2013, 08:57 PM   #51
sfcjetjr
Though so too, but took it out check all, and runs great. Knock on wood!
Old 01-12-2013, 09:22 PM   #52
jpbutler1983
My Ride: 2001 325Ci
Its there a filter Indie three tank too? Or just the one on the fuel line?
Old 01-12-2013, 09:26 PM   #53
FastHackem
My Ride: E60 M5
There is a pre filter attached to the pump assembly.
The Mind Is A Terrible Thing.
2006 M5
2005 Impreza WRX
2002 330i
1983 944
FastHackem is offline   Reply With Quote
Old 01-12-2013, 09:32 PM   #54
jpbutler1983
My Ride: 2001 325Ci
Will that come with the new pump?
Old 01-12-2013, 09:34 PM   #55
FastHackem
My Ride: E60 M5
Yes it does.
2006 M5
2005 Impreza WRX
2002 330i
1983 944
Old 01-14-2013, 08:02 AM   #56
jpbutler1983
My Ride: 2001 325Ci
So here is my BMAparts.com order
I wanted you guys to see this to make sure I haven't missed anything here or if there is something else I should keep in mind.
The fuel pump was cheaper on the BMA website than on Ebay!! so that is good.
the SPECe30 code worked like a charm and saved me 10 bucks.
Altogether, the order comes to about 190 dollars for the new fuel pump assembly, o-ring, and filter. I think this is great, but wanted some input before I pay the money for it. to make sure there isn't another part I'm missing to be able to complete this job.
Thank you guys. You have made this a lot less stressful.
Name:	bmw online order.jpg
Old 01-14-2013, 08:14 AM   #57
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
You need new screw clamps for the hoses. And, I know when I did fuel filter, I replaced a few of the sections of fuel line that were easy to do...probably not essential.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 01-14-2013, 08:18 AM   #58
jpbutler1983
My Ride: 2001 325Ci
can I order the worm clamps from BMA as well?
Old 01-14-2013, 08:19 AM   #59
jpbutler1983
My Ride: 2001 325Ci
or can i just get those from autozone or something... sorry, I know i sound like a noob... it's my first fuel pump, so I'm a little nervous and I want to get it right.
Old 01-14-2013, 08:26 AM   #60
dmax
dmax's Avatar
There are minor differences in screw clamps...you could call and ask bma if they have choices, but I doubt it.
I believe I actually got all my clamps from the dealer...one of the cheapest OE parts you can buy...and I like the little roundel! Not a big deal, I don't think.
Just don't over or under tighten. You want it just compressing the hose, not deforming it much at all.
Mangofy your E46!
