Old 01-12-2013, 03:24 PM   #1
chrisr03325xit
My Ride: 2003 325 xit
SRS Airbag Light Reset Tool in New York area?
Does anyone have an SRS Airbag warning light reset tool in the NY area I might use?
There is nothing wrong with my airbags. I repaired a window regulator (fantastic cheap zip tie repair worked perfectly for little broken plastic part instead of paying for a new regulator).
Even though I'm usually very careful, I spaced out the order of disconnecting the battery before disconnecting the airbag and am now left with a light but cannot afford the tool for a one time use.
Thanks much.
Chris
2003 325 xit
chrisr03325xit is offline   Reply With Quote
Old 01-13-2013, 10:26 PM   #2
enzo_the_baker
My Ride: 328Ci, 328iC, X3
Can't remember if the '03 models still have the 25 pin diagnostic port in the engine compartment, but if so, you can use mine. I drive through Putnam County every day on my commute.
Got Miles?
2000 328Ci Steptronic
Original Engine & Transmission
Original Transmission Fluid
15K Oil Changes
So there!
enzo_the_baker is offline   Reply With Quote
Old 02-09-2013, 04:28 PM   #3
chrisr03325xit
Thanks very much, for some reason just seeing your message. It's the 16 pin under the driver's side dash, but thank you.
Old 02-10-2013, 12:57 PM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
If you're going to queens anytime soon PM me and I will scan it for free
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 07-06-2013, 04:15 PM   #5
chrisr03325xit
Forgot to say Thanks very much for the offer in Queens, I ended up ordering one and now have the Peake reader. If I can be of help to anyone let me know.
