Old 01-12-2013, 06:24 PM   #1
KH0
My Ride: 323i
Exclamation E46 Manual Fan Removal - Stuck!
Hello,
I was in the process of removing the fan, but the fan is stuck halfway while pulling up?
FYI: I followed the procedure here http://www.beisansystems.com/procedu..._procedure.htm
Thank You.
KH0 is offline   Reply With Quote
Old 01-12-2013, 07:17 PM   #2
sfcjetjr
My Ride: 2002 BMW 325i
As long as fan shroud is all unplugged and the fan nut is totally unscrewed, both should just slide right out. Check the slots that the shroud has on the sides and on the bottom, and ensure to remove electric fan relay from passenger side of shroud.
sfcjetjr is offline   Reply With Quote
Old 01-12-2013, 10:27 PM   #3
KH0
My Ride: 323i
fcjetjr,
Thanks for your help I will look into it more tomorrow. It is hard working on a car when it's freezing outside.
LOL
Old 01-14-2013, 06:28 PM   #4
KH0
My Ride: 323i
This was getting stuck so I had to push it in a bit to get it out.
Name:	E46 Manual Fan Removal - Stuck!.jpg
