Sponsored by BimmerWorld
Old 01-13-2013, 02:06 AM   #1
swaggerwagon
My Ride: 2005 330i
Coilover question before install
I just got a set of Raceland ultimo coilovers...I have read the opinions of Raceland on the forum and some are for and against them.
I am not going for performance with these. They are just to close off the wheel gap and replace my leaked out shock and struts.
I have seen people running spacers with aftermarket wheels and before I put these on and waste a couple hours doing so only to switch them back to my busted suspension. Do I need to run spacers with OEM style 135 wheels or can I clear everything without
330i ZHP
3 Pedals FTW
BMW level 2 Tech
Ebay headers | Long tube CAI | modbargains ///M pedal covers | SS clutch line | CDV removed | Turner camber arms | Meyle HD FCABs | uuc poly motor/trans mounts | Eurospec Muffler | Clutch masters Stage 2 with aluminum flywheel | Coilover kit | CSL front bumper | Z4m shift lever | VISracing CF hood | Depo HID w/CCFL halo rings
swaggerwagon is offline   Reply With Quote
Old 01-13-2013, 12:43 PM   #2
fth001
My Ride: 325i, e36m3, s13
Yes, you will need a 5-8mm spacer minimum. 10mm's will guarantee you will be on the road after install.
fth001 is offline   Reply With Quote
Old 01-14-2013, 12:16 PM   #3
swaggerwagon
My Ride: 2005 330i
thanks. ill get the 10s just to be on the safe side
330i ZHP
3 Pedals FTW
BMW level 2 Tech
