///M3 Forum
Old 01-13-2013, 06:35 AM   #1
AhmadYAl-Hamed
My Ride: 03 E46 M3 individual
M3 navi screen not working??
Hi, I'm having a problem with my M3 E46 , well i don't use it often maybe like twice a month, and when took it out, I realized that the screen isn't working, I press everything and nothing happens.. Only when I turn on the lights, the lights inside the buttons light up , that's it.. And the controls from the steering wheel used to work from about a month ago, but now there's nothing.. Please help on how to fix this.. I would take it to a shop but it would have to stay a whole day there, and as I am busy with work, I can't take it to the shop and then back home on the same day, and I don't like having my M3 staying in a shop for a night. So please help me if you can or at least if you can tell me what's the problem.. Thanks!
AhmadYAl-Hamed is offline   Reply With Quote
Old 01-13-2013, 10:02 AM   #2
j3nks79
My Ride: E46 M3 Individual
Take the fuses for the nav out and re fit. Also disconnect the battery for 5 mins
j3nks79 is offline   Reply With Quote
Old 01-13-2013, 10:09 AM   #3
AhmadYAl-Hamed
Thanks, ill reply once I've tried it.
Old 01-13-2013, 12:44 PM   #4
AhmadYAl-Hamed
Well, I tried it, the fuses didn't work but the battery did, but its not a whole fix, it only made the radio work, but the screen isn't working, and also im able to take a cd out now, I couldn't before I did that trick, I still can't listen to anything but the radio. Buttons still don't work, but its better than having nothing to listen to! Thanks!
Old 01-13-2013, 07:52 PM   #5
NICKBRUM
My Ride: 2004 M3
I had my navigation computer die, which causes a blank screen with intermittent flickering. If you have a friend close by with a M3 ask to plug their computer into your car to verify. Its very quick and easy.
Current:
2006 E46 M3 ZCP silver gray on black SMG
|Stoptech BBK ST40 X 355mm| Style 219 wheels|
|Ceramic coated euro headers| Custom 200 cell section 1|
|TTFS Motor & SMG tune, 315 whp| GC coil overs |
Previous: Totaled
|Carbon Fiber Intake|AA GEN3|AC Strut Brace|Eibach/Koni's|CSL/SMG Flash|
|Victory UDP's|HPF Sub Frame Plates| PF Subframe Bushings|Rtab Limiters|PFC DD Front Rotors|
NICKBRUM is offline   Reply With Quote
Old 01-13-2013, 09:09 PM   #6
choxor
My Ride: JDM
Is the screen on, but blank, or completely dead?
Old 01-15-2013, 05:35 AM   #7
j3nks79
Check your bm54 unit
