Old 01-13-2013, 01:27 PM   #1
BMWCurves
My Ride: 2005 330Ci ZHP 6MT
Good BMW Specialist Mechanic in Philadelphia
Hi all,
I'm in the market for an e46 BMW 3-Series and I have one lined up. I took it over to BMW in Devon Hill, PA to have it inspected, but they didn't run a compression test or look at the spark plugs, and pretty much did a bare minimum inspection (my own fault for not being specific to my needs). At any rate, I'm looking to have it inspected again, but I'd like to take it to a mechanic that specializes in BMWs. Does anyone know or go to a BMW specialist mechanic in the Philadelphia, PA area? Any help would be greatly appreciated, thanks!
BMWCurves is offline   Reply With Quote
Old 01-13-2013, 03:26 PM   #2
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Remember to have the subframe inspected.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 01-13-2013, 04:22 PM   #3
theOCHO
My Ride: 330i ZHP 6MT
When I need work done I hit up VAC Motorsports. They're in South Philly, on Snyder Avenue I think. But if you need cheap parts from the dealer, I found that West German BMW is the cheapest. Their labor rate seems to be the cheapest among dealers.
Good luck.
theOCHO is offline   Reply With Quote
Old 01-13-2013, 04:23 PM   #4
Zchild
My Ride: 2000 BMW 3XXi ZSP
+1 on VAC Motorsports...
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Back-Up Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Old 01-13-2013, 04:25 PM   #5
BMWCurves
Will do. I'm having whoever I end up going to look over:
- Cylinder compression using either a compression test or a leak down test for various leaks (oil rings, piston rings, valve leakage, etc).
- Underneath the car for worn bushings and suspension components as well as any rust or any issues with the exhaust since I live on the east coast and they salt roads more frequently. As well as any signs of body work.
- Any oil leaks in the engine bay.
The car I'm currently looking at has somewhat erratic maintenance, but if I purchase it I expect to do new coolant, engine oil, hoses, belts, differential and transmission fluids, brake fluid, valve cover gasket, radiator (never replaced and is set to crack soon on the inlet), and pulleys regardless of its maintenance. I just want to make sure the heart of the car doesn't have premature wear.
