Go Back   E46Fanatics > Everything Else > The Off-Topic > Gun Talk
Gun Talk
Are you a gun fanatic as well? If so, you'll want to talk to other owners about what you own in this forum.
Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 01-13-2013, 08:51 PM   #1
HiHoBrian
My Ride: 05 M3
Glock slide rail flaking
My G27 gen4 rear slide rails have the nickle coating flaking off and copper exposed. There is under 200 rounds on this gun and it seems like a bad plating job. How common is this,can or should I call glock for repair,or do I just hone and polish it down the shoot the heck out of it for ten years and never think about it again? Click image for larger version
ID:	485909Click image for larger version
sent from my ATARI sc1224
HiHoBrian is offline   Reply With Quote
Old 01-13-2013, 09:11 PM   #2
Serbonze
Master of his domain.
My Ride: My wife
Originally Posted by HiHoBrian View Post
My G27 gen4 rear slide rails have the nickle coating flaking off and copper exposed. There is under 200 rounds on this gun and it seems like a bad plating job. How common is this,can or should I call glock for repair,or do I just hone and polish it down the shoot the heck out of it for ten years and never think about it again? Attachment 485909Attachment 485913
Glock uses a copper lubricant from the factory. Are you sure that it's not just the original lubricant wearing off exposing the slides, and not the metal wearing off exposing copper slides (the slides are not made of copper).
Serbonze is offline   Reply With Quote
Old 01-13-2013, 10:20 PM   #3
Reedo302
Reedo302's Avatar
My Ride: F30 328i M Sport
That's normal. Nothing to worry about. Don't polish anything, don't hone anything, nothing.
DINAN3 F30 328i M Sport
DinanTronics Stage 1
Dinan Free Flow Black Tip Stainless Exhaust
Dinan Lowering Springs and Bumpstops
Dinan 20" Black Performance Wheels
Gunfighter Training Development and Evaluation
AR15/AR10 Armorer/Advanced Armorer
Glock Armorer
Gunfighter Training YouTube Channel
Reedo302 is offline   Reply With Quote
Old 01-13-2013, 11:07 PM   #4
GasKing
My Ride: 1990 Yugo GVC
+1 On my first Glock the same thing freaked me out. Check out Glocktalk.com
GasKing is offline   Reply With Quote
Old 01-13-2013, 11:12 PM   #5
HiHoBrian
My Ride: 05 M3
I saw the original copper lube when the gun was new. This is definately the outter layer of plating that is comming off exposing the apparently copper plating under layer,similar to a chrome plating prosess,of the steel rail. It catches a finger nail or a tool. So Reedo,does it eventually smooth itself out without gouging the slide? I have never seen this happen with a gen3 (this is my only gen4) and also there is no wear on the front rails.
Edit: checked out glocktalk,its common and possibly coated for corrosion resistance and like you said Reedo,works itself out with use. Thanks.
Old 01-14-2013, 03:08 AM   #6
carcus
My Ride: 2006 BMW M5
Yep, normal. Glocks are simple and built like tanks. Pics do not look that bad to me. As normal with a Glock, fire and forget.
2006 M5 E60, "Lord Vader" Last real NA M series
German Car Fanatic. Colorado ///M Flight member, BMW CCA member.
carcus is offline   Reply With Quote
Old 01-14-2013, 06:51 AM   #7
GlockMan
GlockMan's Avatar
My Ride: Suburban LT 4x4
Its a Glock. Leave it alone.
!!! ROLL TIDE ROLL !!!
National Champs: 1925, 1926, 1930, 1934, 1941, 1961, 1964, 1965, 1973, 1978, 1979, 1992, 2009, 2011, 2012, 2015, 2017?
Ranting about Panny plasmas, Canon cameras, Glocks, BlueNile, and HDMI on a BMW board since 2005.
2016 Honda Accord Sedan V6 Touring (wife)
2007 Chevy Suburban LT 4x4 with Nav/Bose/DVD
1968 Ford Mustang with Polk/ADS (my first car)
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
GlockMan is offline   Reply With Quote
Old 01-14-2013, 11:15 AM   #8
sfcjetjr
My Ride: 2002 BMW 325i
Like when buying older used weapons, 1st it must fire! 2nd, is wear and character showing use but also the care put into the weapon. Unless it is for your wall or just to show off to your buds. Leave it alone, use it often and maintain well.
sfcjetjr is offline   Reply With Quote
Old 01-14-2013, 05:21 PM   #9
HiHoBrian
My Ride: 05 M3
This is my EDC bought new a few months ago and barley has gone 200 rounds. It just had me concerned that stuff was flaking off so soon. I'll put a few hundred more through it and see if it smoothes itself out. I would like to see some other examples of this to tell if it is just a gen 4 issue,or non-issue.
Old 01-14-2013, 05:43 PM   #10
king kong
My Ride: mid-engine
Did you even read HiHo's post? He's asking what he needs to do to maintain it
king kong is offline   Reply With Quote
Old 01-14-2013, 06:29 PM   #11
Reedo302
Reedo302's Avatar
sent from my KARATEDISHWASHER sc1224
The tenifer coating on the slide is extremely hard, and that coating is inside the slide rail grooves. There's bound to be some wear present. Since the gun is basically new and barely fired, it's normal to start to see some visible wear developing. Give it more time and more rounds fired through it, and it'll smooth out normally. The components involved are the same between Gen3 and Gen4, so it's not a generational issue. I've seen this occur on all new Glocks I've ever looked at or inspected.
Glock Armorer
Old 01-14-2013, 06:56 PM   #12
HiHoBrian
My Ride: 05 M3
Ok, now that I have learned more about it I am glad it is not a concern. Thanks for the extra input. I guess its time to test out my new mags that were just delivered.
Old 01-14-2013, 08:58 PM   #13
MpoweredM
Wants to be Orange
MpoweredM's Avatar
My Ride: 1098S; RR Sport; CRZ
Want to know how many times I cleaned my first glock after 5 years of ownership? 2 times (one time a friend did it because he was bored). . Never failed. Loved it. Sold it for a m&p 15/22 and had to purchase another glock because I missed it.
Santa Hats thanks to Scott!
Click for pics of my bikes
Click for pics of my old 335
Click for pics of my old S4 avant
Click for pics of my old M3
Originally Posted by v8 5 View Post
Constatine would of thrown his dildo at the kidnapper and proceed to cry in his closet after said kidnapper escaped.
MpoweredM is offline   Reply With Quote
Old 01-14-2013, 11:43 PM   #14
Reedo302
Reedo302's Avatar
Yeah, I'd be lying if I said my EDC Glock 27 was clean right now.
Glock Armorer
Old 01-14-2013, 11:59 PM   #15
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
Send a message via AIM to JonJon
It's a Glock.
Keep cleaning and scrubbing the ugly off it until it turns into a Springfield
JonJon is offline   Reply With Quote
Old 01-15-2013, 04:49 AM   #16
Reedo302
Reedo302's Avatar
Didn't know you could turn Austrian into Croatian...
Glock Armorer
Old 01-15-2013, 04:59 AM   #17
XKxRome0ox
Black and Proud
My Ride: RIP e46/'16 328i
Originally Posted by JonJon View Post
It's a Glock.
[bimmerapp]
2016 BMW 328i 6MT/M Sport Package/Track Handling Package/BMW M Performance Exhaust/Injen CAI
XKxRome0ox is offline   Reply With Quote
