///M3 Forum
Old 01-14-2013, 08:04 AM   #1
PITT M3 RR
My Ride: E46 M3
Will I need adjustable camber arms?
I have PSS10s on the way, I don't plan on slamming the car by anymeans. I bought them to tighten up the car a bit and because the stock suspension has 109K. I drive the car on the street 90% of the time.
I dont want to kill my tires with an un-needed aggressive setup only to be used on the street. So will I need camber arms if I come down maybe an inch front and rear or will stock adjustability not be enough?
UUC SSK / AFE STG1 Intake / AKG Red Motor mounts / AKG Red Tranny mounts / AKG Red Subframe bushings / AKG Red Differential bushings / AKG Red RTABS / TMS Subframe reinforcement / Custom in trunk subframe structural brace / Bilstein PSS10's / Ground control camber plates / Turner RSM
PITT M3 RR is offline   Reply With Quote
Old 01-14-2013, 08:40 AM   #2
S54Dan
My Ride: '05 M3 '03 ZHP
I don't think so. I use AST4100 and it's lower than 1 inch from stock. Any good alignment shop should be able to align it correctly for street use.
2005 M3 6MT | Weekend toy & Track rat
2003 330i ZHP 6MT | Wife Mobile
1994 325i 5MT | DD
Instagram @S54Dan
S54Dan is offline   Reply With Quote
Old 01-15-2013, 01:31 AM   #3
illestminimike
My Ride: Project Drama
Stock should be enough. But some camber arms would still be nice.
Old 01-15-2013, 11:13 AM   #4
PITT M3 RR
My Ride: E46 M3
Thanks for the info guys, I guess I'll hold off if it isnt a needed expense right now. I just didnt want to murder my tires, I dont need -3 on the street or stupid amounts of toe.
Old 01-17-2013, 04:23 PM   #5
api
My Ride: 03 M3 6-spd
No, you will not need the adj rear camber arms. I ran the OEM arms when I put my PSS9s on the car and did not have any issues at all.
I will say that when I installed the TMS Rod-End Rear Camber Arms on my car that I noticed the rear end gave more feedback and had less play but that is to be expected when going from a gel filled bushing to a pivot bearing. I love the things but they are not needed for the street.
PS: the driver's side bolt by the diff is a pain to install but worth it.
MODS: 03 M3, 6MT, PSS9, AFE Intake, Euro Ceramic Coated Headers, El Diablo Exhaust, Turner Motorsports Rear Adjustable Camber Arms, AKG Diff and Subframe bushings, PowerFlex suspension bushings, Sub-frame Reinforcement, 18'x9' square setup & one driver that grins ear to ear everytime he is driving it
api is offline   Reply With Quote
Old 01-17-2013, 04:27 PM   #6
PITT M3 RR
My Ride: E46 M3
Great info guys thanks!
Ill just reinforce the stock arms like i did on my E36 M.
Way to save me 300!
