Old 01-14-2013, 08:36 AM   #1
jpbutler1983
My Ride: 2001 325Ci
Fuel Filter
Good morning,
I am in the parts ordering process of replacing my fuel pump and I figured I may as well order the filter as well and just do a fuel system overhaul...
I checked on Ebay and came across a company called kayser and I wanted to know if anyone has ever had any problem with them, or can verify that they are a reputable source:
http://www.ebay.com/itm/BMW-OEM-Fuel...afda17&vxp=mtr
Thanks for the assist
A man will be the same with a title as he was without one
jpbutler1983 is offline   Reply With Quote
Old 01-14-2013, 08:37 AM   #2
jpbutler1983
My Ride: 2001 325Ci
or should I just go with these guys, since they actually list OEM in their description:
http://www.ebay.com/itm/BMW-E46-325i...7c42fa&vxp=mtr
Old 01-14-2013, 08:38 AM   #3
jpbutler1983
My Ride: 2001 325Ci
this one is the same company as the first link but says OEM made in germany and they have sold 25 of them with positive feedback...
http://www.ebay.com/itm/EDM-GENUINE-...591e85&vxp=mtr
Old 01-14-2013, 08:42 AM   #4
jpbutler1983
My Ride: 2001 325Ci
i also hear a lot about Mann...
http://www.ebay.com/itm/MANN-FILTER-...b10ff9&vxp=mtr
Old 01-14-2013, 08:55 AM   #5
WDE46
My Ride: '13 128i, '04 330Ci
Mann, Mahle, or Kayser are all fine. Pick one and be happy.
Old 01-14-2013, 08:57 AM   #6
lsteg
My Ride: 2001 330ci
Mann
lsteg is offline   Reply With Quote
Old 01-14-2013, 08:58 AM   #7
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
OP,
there is nothing wrong with buying stuff on ebay as long as you know exactly what you are looking for. however, based on my experience you will have better luck (price and customer service) dealing with the sponsors on here. ebmwparts and thebmwpartstore sell original/genuine BMW parts. If not, you can always buy the same part from pelican or BMA auto parts. these places offers free shipping too (restriction applies).
I hope this helps. good luck!
Old 01-14-2013, 09:16 AM   #8
jpbutler1983
My Ride: 2001 325Ci
well here is my order.
I went with BMAparts.com because their reliability was verifiable.
the specE30 coupon code saved me 10 bucks.
here is a screenshot of my cart.
am I missing anything?
Name:	bmw online order.jpg
Old 01-14-2013, 09:21 AM   #9
flashmeow
Banned User
awesome! You will also be impress with BMW Auto shipping. they have the best one in the business. sometimes their parts arrived before you even hit the submitt button...really it is that impressive
Old 01-14-2013, 09:22 AM   #10
jpbutler1983
My Ride: 2001 325Ci
where can I get the worm clips... since I am going to need to replace the crimp on that is most likely installed?
Old 01-14-2013, 09:29 AM   #11
WDE46
Yes you will need to replace the hose clamps. Buy some at the hardware store that are close to the same size. BMW uses clamps that are designed to not be reused easily.
When you change the filter, you'll want to loosen the BMW clamps and move them aside. Then you take some slip-joint pliers (regular pliers) and grip the hose over the fuel filter connection and twist. It should make a pop sound. This breaks the hose's seal on the filter and it will slide off with a few more twists/pulls.
I would also recommend changing the short 3-4 inch pieces of fuel hose that connect to the filter. Go to the auto parts store and buy some "Fuel Injector" hose (it is rated for higher PSI). Get 5/16 inch internal diameter (it's almost exactly 8mm like the OE stuff).
Old 01-14-2013, 09:34 AM   #12
jpbutler1983
My Ride: 2001 325Ci
thanks for the advice. will do.
Old 01-14-2013, 09:38 AM   #13
WDE46
Oh and you'll probably tear the rubber vacuum tube coming from the pressure regulator on the end of the filter. I tore mine but it had enough extra to slide back on. If you are unlucky, you'll need some 3mm internal diameter vacuum tubing.
Old 01-14-2013, 11:22 AM   #14
jpbutler1983
My Ride: 2001 325Ci
yep. already called autozone. They have the vacuum hosing, the 5/16 fuel injector hosing and the screw clamps. and I just ordered all the parts from BMA... so now it's a waiting game.
Old 01-14-2013, 11:26 AM   #15
flashmeow
Banned User
Great point but I recommend the silicone hose rather than the rubber hoses. All BMW vacuum hoses are now silicone.
I am not sure if autozone stock silicone. The last time i check they have to order it. They do have plenty of rubber vacuum hose though
sent from my HTC EVO+ using Bimmer App
Old 01-14-2013, 11:50 AM   #16
LA Prince
Banned User
My Ride: Not Your Business
Go with Mann man !
LA Prince is offline   Reply With Quote
Old 01-14-2013, 11:53 AM   #17
Treburkulosis
My Ride: BMW
Originally Posted by LA Prince View Post
Go with Mann man !
Agreed.
Treburkulosis is offline   Reply With Quote
Old 01-14-2013, 11:55 AM   #18
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Buy the relay as well.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 01-14-2013, 12:03 PM   #19
beauch3
My Ride: BMW 325
Just be prepared when you replace the pump for possible fuel level sensor problems. I am struggling with one now. Make sure that the level sensor arm moves up and down freely before for you install the new pump.
beauch3 is offline   Reply With Quote
Old 01-14-2013, 12:22 PM   #20
trj
My Ride: 325Ci
The cart looks good.
But as you already figured, you will need about a foot of fuel injector hose(not regular fuse hose), 3 small hose clamps and about 6 inches of vacuum hose(forgot the dimension). All of it can be purchased in a local part store.
Plus you might want to pick up a pair of safety goggles(I got mine from harborfreight for $2) to remove the fuel filter. The fuel is going to spray on your face when you are spread eagle under the car, unless you have a lift. Petrol is not tasty nor is soothing in the eyes, hence the goggles is a must.
Turn off the car, remove the fuel filter fuse, crank till it doesnt start anymore. In short starve the lines off fuel. Open the fuel door. These are the steps you should take before working on the fuel filter. Of course, do not smoke or light anything nearby.
Make a note or take a picture of the original position of the fuel filter for the reference. Many here have mismatched the hoses and had no start problems.
Good luck
