Sponsored by BimmerWorld
Old 01-14-2013, 11:06 AM   #1
daveion2002
My Ride: 2001 330i
Coil help :/
Put in new street edge coils in. The front is clunking though. so before I take it to a mechanic what could be wrong?
daveion2002 is offline   Reply With Quote
Old 01-14-2013, 11:06 AM   #2
My Ride: Lexus
you put in new street edge coils.
Old 01-14-2013, 11:10 AM   #3
daveion2002
My Ride: 2001 330i
Ohh come on I'm sure I just ****ed up I've read a lot of people that have them and they are just fine
Old 01-14-2013, 11:26 AM   #4
RayPooley
My Ride: 320i SE Coupe
Is it possible you might have damaged an FCAB during the process? Maybe one was ready to give up and, by removing the strut, it caused the rubber to come apart. Everything else on the strut tightened up properly?
Old 01-14-2013, 11:30 AM   #5
daveion2002
My Ride: 2001 330i
I don't think so... They are brand new. Yeah every thing is tightened down to the right torque specs. Would an alinement fix it maybe?
Old 01-14-2013, 11:32 AM   #6
WDE46
My Ride: '13 128i, '04 330Ci
Check the top nut on the strut mounts. That one is difficult and could have loosened once the suspension had weight on it. Also, look at the connection of the strut to the steering knuckle. Make sure it is settled all the way down and any slots are aligned properly.
Old 01-14-2013, 11:36 AM   #7
My Ride: Lexus
I don't like giving advice on bad parts because i feel like i'm condoning it. but it's probably a loose end link or bearing/plates.
Old 01-14-2013, 12:00 PM   #8
RayPooley
Last time I changed struts it was stock for stock so no need to touch steering geometry. Don't know enough about your new coils. Its quite a simple job really. What is it? Three bottom bolts and three nuts at the top? I can't really think of where you could go wrong. Get it up on axle stands and move the wheels left and right by hand see if anything moves that shouldn't. Sorry dude. That's all I got.
Old 01-14-2013, 12:37 PM   #9
daveion2002
My Ride: 2001 330i
yeah I know i went cheap but I could have done worse and gone with Race lands!
Old 01-14-2013, 12:40 PM   #10
daveion2002
My Ride: 2001 330i
Ill check those nuts and make sure every thing is tight. I was just looking at my job and it looks like the left strut is turned a little to the right (sway bar mount is turned) when the roters/ wheels are facing strait forward. Could this be the problem?
Old 01-14-2013, 12:47 PM   #11
My Ride: Lexus
how much were they if you don't mind me asking?
Old 01-14-2013, 12:48 PM   #12
My Ride: Lexus
Even if its not, make sure everything is perfectly angled. always start with a proper install
Old 01-14-2013, 12:49 PM   #13
Zell
Zell's Avatar
My Ride: so turbo wow
lolracelands
Old 01-14-2013, 02:22 PM   #14
daveion2002
My Ride: 2001 330i
Don't mind at all. It was 395 with free shipping. It came with shortened sway bar links also.
Old 01-15-2013, 10:44 AM   #15
daveion2002
My Ride: 2001 330i
So the spring noise went away is that good or bad?
