Sponsored by The Tire Rack
Old 01-14-2013, 01:52 PM   #1
Cali Chase
My Ride: 2002 325i
tire pressure questions
so i have noticed some play in my steering wheel and decided it wolld be a good idea to check my tire pressure. My front tires, Kumho ecsta 225/40 r18 are at 27 psi and my rear dunlops, 255/34 r18 are at 28psi. That seemed normal to me being that i filll my tires to about 28 or 30 but the labels on the tires say to fill to 50 and 51 psi respectively. That seems way to high...
**pm me for custom carbon fiber work and repair**
2007 Interlagos Blue Z4 ///M Coupe #1197 out of 1815
Porsche gt2/carrera gt cf seats l Apex arc-8s l R888s l BC Coilovers
Cali Chase is offline   Reply With Quote
Old 01-14-2013, 02:04 PM   #2
Poncho@home
My Ride: MY04 330Cic ZSP
max PSI is typically around @50, however that is too high for normal driving.
under 30 is also a little low IMO. I normally run anywhere from 32 to 36, depending on car, tire ride quality.
Poncho@home is offline   Reply With Quote
Old 01-14-2013, 04:34 PM   #3
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
+1
I would not fill your tires up to 50 PSI, and 27-28 seems low. I believe the tire pressure info should be on the door jamb though if you'd like to run what's recommended for your car.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 01-15-2013, 04:51 AM   #4
jadatis
My Ride: Seat Alhambra
For savety of the tires, you better keep the pressures high, mayby even higher then you have now. Comfort and gripp are bad then ,but you dont risk a blow out.
Tires with low aspect ratio ( further AR = the 35 in your 255/35 R 18 ) are to high calculated in their maximum load ( on the sidewall Loadindex or maximum load printed) by the tire-makers, and so deflect more then is save for them, when you put maximum load and reference-presssure on them.
This is a thing the tire-makers wont tell you.
If you give me the GAWR's front and behind and the maximum load or loadindex of the tires, and the type of tire, I can calculate a save pressure for fully loaded, what after 2000 is called normal use advice.
If you can produce empty weight or curb weigt and weight division front /back, and the way you normally load the car ( Persons and load), I can estimate the normal use axle loads and calculate an advice-pressure for that .
Reference pressure i mentioned is the pressure the maximum load can be carried ( according to calculations) up to the reference speed of probably 190km/??m/h for your W speedrated tires, without damaging the tires by driving alone. this is lower then the maximum pressure of that 50 and 51 psi that is only printed on P-tires/standard load and Extraload/XL/reinforced.
So search on the sidewall for the last ( XL etc).
American P-tires Pr ( referencepressure/maxloadpressure) 2,4bar/35psi
American XL tires Pr 2,8 bar/41psi.
Difference between Pr and Pmax is used for higher speed and camber-angle above 2 degrees ( alignment tires like this /-\ on the axle instead of this|-|)
jadatis is offline   Reply With Quote
Old 01-15-2013, 05:46 PM   #5
Jim Clark
My Ride: 2001 330Cic
Jim
2001 330Cic, Oxford Green Met, Sand, Step, Premium, Sports
Jim Clark is offline   Reply With Quote
