Sponsored by BimmerWorld
Old 01-14-2013, 02:03 PM   #1
njmisso
My Ride: 2004 zhp 330i sedan
Alignment?
Do you get an alignment when switching from a summer setup to your winter?
Running summer:
18x8.5 et40 (front) & 18x9.5 et45 (rear)
Winter: 17x8 (fronts & rears)
njmisso is offline   Reply With Quote
Old 01-15-2013, 12:55 PM   #2
hummer
My Ride: 2001 330CI
I would check the summer tires when they come off to determine if there is any strange wear pattern going on. If they look good, just put the winters on.
Old 01-15-2013, 01:12 PM   #3
littlegti
My Ride: 2002 330ci conv
+1 above
This year when I switched to winters, a check of my summers showed they were worn poorly and the tread depth was at the limit. My winter tires are near new with no unusual wear patterns. The alignment with the winters on is clearly off. My plan is to completely overhaul the suspension this spring and then get an alignment with a new set of summer tires.
littlegti is offline   Reply With Quote
Old 01-15-2013, 03:05 PM   #4
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Good advice.
While it may not be necessary, there are indications that you could need one based on your tirewear.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 01-17-2013, 07:17 PM   #5
njmisso
Thanks for the advice. I just picked up new summers and winters so I wanted to be sure.
Old 01-22-2013, 01:22 AM   #6
njmisso
So I went to dealership and looks like my rear lower control arms are slightly bent and I should get new ones before doing the alignment.
My suspension is good otherwise but I want to do a coilover kit (or maybe koni's & springs) soon.
Should I get the adjustable kind now with my OEM zhp suspension? Or will the OEM work fine with a kit in the near future?
Comments are appreciated.
Old 01-22-2013, 04:10 PM   #7
J.Schmidt
My Ride: E46 M3
I had the same problem...makes a big difference with the new arms.
J.Schmidt is offline   Reply With Quote
