///M3 Forum
Old 01-14-2013, 03:57 PM   #1
JoseRonaldoVargas
My Ride: My feet
Maintenance & Cost
What do you guys recommend I do daily/weekly/monthly/yearly to keep an M3 running strong ?
About how much do you spend in maintenance ?
Reason why I ask is i'm looking forward into buying one
Thanks in advance .
JoseRonaldoVargas is offline   Reply With Quote
Old 01-14-2013, 04:38 PM   #2
corNIC
My Ride: '01 M3, '06 x3
I just got one last week and I'm sort of wanting to know the same thing, and I'm also sort of not wanting to know the same thing lol.
corNIC is offline   Reply With Quote
Old 01-14-2013, 04:52 PM   #3
S54Dan
My Ride: '05 M3 '03 ZHP
I'd say after 100k miles, prepare to spend some money. My M3 went through a bit of a depression in 2012. I track the car a lot so I'm sure I put the parts on more strain, but it would have gone out eventually.
2012 repairs: Fuel pump, fuel filter, RTABs, fan clutch, t-stat, water pump, coolant tank, front brakes complete (pads, rotors, sensor), rear pads, new tires, belts, and all four wheel bearings.
Edit; Forgot to mention inner and outer tie rods, steering column guibo, driveshaft guibo, and center support bearing.
2005 M3 6MT | Weekend toy & Track rat
2003 330i ZHP 6MT | Wife Mobile
1994 325i 5MT | DD
Instagram @S54Dan
S54Dan is offline   Reply With Quote
Old 01-14-2013, 05:33 PM   #4
choxor
My Ride: JDM
Go to the e46 section of m3forum.net and read the stickies.
Old 01-14-2013, 06:18 PM   #5
taylor192
My Ride: 2003.5 M3
Do this daily:
Do this monthly:
Do this yearly:
Old 01-14-2013, 09:49 PM   #6
NICKBRUM
My Ride: 2004 M3
^ Puahahahaha!!! But seriously OP there are too many factors, to pin down a number. Owing a E46 M3 is like a mothers unconditional love. Despite all its faults you love it, regardless of the stupid sh!t that fails. No matter what it is not a low maintenance car. Working on it yourself can save a whole lota mooola.
Current:
2006 E46 M3 ZCP silver gray on black SMG
|Stoptech BBK ST40 X 355mm| Style 219 wheels|
|Ceramic coated euro headers| Custom 200 cell section 1|
|TTFS Motor & SMG tune, 315 whp| GC coil overs |
Previous: Totaled
|Carbon Fiber Intake|AA GEN3|AC Strut Brace|Eibach/Koni's|CSL/SMG Flash|
|Victory UDP's|HPF Sub Frame Plates| PF Subframe Bushings|Rtab Limiters|PFC DD Front Rotors|
NICKBRUM is offline   Reply With Quote
Old 01-14-2013, 09:50 PM   #7
turbo_f22_pilot
My Ride: 2 pedals - 2 paddles
^^^bwahhhhahahhahhhahh
Just expect to spend $2500 yearly. And if you don't, the next year will make up for the difference.
In order to finish FIRST, you MUST first FINISH !
Joy is future proof
Get your "M" on . . .
Reading is FundaM3ntal
CAR:
2003 TIAG Coupe / Blk Interior / SMG / HK Premium
MODS:
EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust
Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB
BMWCCA NCC
turbo_f22_pilot is offline   Reply With Quote
Old 01-14-2013, 11:30 PM   #8
JoseRonaldoVargas
My Ride: My feet
Lmao @taylor
Old 01-14-2013, 11:31 PM   #9
JoseRonaldoVargas
My Ride: My feet
$2500 not bad . Thanks .
Old 01-14-2013, 11:33 PM   #10
Grendelsbane
My Ride: M3
taylor192 FTW!!!!
2004 Silver M3 / SMG / Koni Yellow shocks and struts / Vogtlands lowering springs / Eibach front and rear sway bars / Proflex bushings / Predator Orion V2 Multi-Color LED Angel Eyes / Laser Interceptors / Clear Bumper Reflectors / Mishimoto Aluminum Radiator / AKG Motor mounts / Rogue Engineering Transmission Mount / AKG differential bushings / Euro mirrors / B&B Exhaust / CSL SMG tune /DME CSL tune
Grendelsbane is offline   Reply With Quote
Old 01-15-2013, 12:16 AM   #11
rcsummers
My Ride: M3
this. I've spent roughly that every year since I've had the car on maintenance. Although a lot of it is preventative stuff. But if your mechanically inclined with a set of tools, you can save yourself some money here and there.
"RICH"
My Build Thread
EURO.TECHNIKS
- Status Gruppe Tuning - Broadway Static - Recaro - DTM Fiberwerkz - AutoCouture Motoring -
Instagram: @summers_e46_m3
Twitter: @rcsummers0506
Xbox One: MisterMeisterM3
rcsummers is offline   Reply With Quote
Old 01-15-2013, 12:26 AM   #12
JoseRonaldoVargas
My Ride: My feet
Do you guys get a PPI and use that as a guide for the maintenance ? Still $2.5k ?
Old 01-15-2013, 12:33 AM   #13
rcsummers
My Ride: M3
I got a PPI before I purchased the car. Only way to know what your getting into.
"RICH"
My Build Thread
EURO.TECHNIKS
Old 01-15-2013, 02:11 AM   #14
Grendelsbane
My Ride: M3
I know a mechanic and he looked at the car before I bought it. Most of my expenses last year were just preventative or an upgrade. New shocks and springs to lower the car, new radiator and water pump, new RTABS and FCAB, and motor and tranny mounts.
This year I am going to change out my fuel pump and the alternator.
Old 01-15-2013, 02:13 AM   #15
taylor192
My Ride: 2003.5 M3
Dude, it just depends on the car you get. My car checked out fine, yet in 1 year I have had to fix:
- leaking steering hose
- vanos solenoid
- convertible top hydraulic cylinders
and decided that after 80K miles I should replace:
- RTABs
- FCABs
- end-links
- brake pads front and rear
- shocks
and almost once a year you'll need an oil change.
Thus in my first year I'm out $800 in necessary repairs, and $1100 of maintenance plus my own sweat and tears cause I did everything myself. Double or triple that total if you need a shop. I suspect I'll need a water pump and fan clutch at some point soon, so tack on another $500.
I've spent more on discretionary stuff (grills, lights, springs, diffuser, lip, SSK, wheels, ...) than I have on maintenance.
Old 01-15-2013, 07:26 AM   #16
JoseRonaldoVargas
My Ride: My feet
Alright . Thanks . Thanks for replying guys .
Another thing how much did that convertible hydraulics cost ?
Old 01-15-2013, 11:59 AM   #17
alkemyst
My Ride: 06 TiAg M3 ZCP 6M
An M3's maintenance is basically a checklist at mileage intervals. I drive roughtly 2200 miles a month, in my first year of ownership my maintenance was about $4500. Not counting a full set of tires and 2 oil changes @ $200 a pop.
alkemyst is offline   Reply With Quote
Old 01-15-2013, 12:06 PM   #18
JoseRonaldoVargas
My Ride: My feet
How about insurance ? Anyone got allstate ?
Old 01-15-2013, 12:16 PM   #19
taylor192
My Ride: 2003.5 M3
Dude, you need to ask less and research more. Insurance varies by region, record, age, sex, martial status, ... so asking what others pay is just a shot in the dark unless you can find your twin online, and even then...
Old 01-15-2013, 12:18 PM   #20
taylor192
My Ride: 2003.5 M3
$110 per cylinder to rebuild. There are 6 cylinders, 4 of which are very easy to remove, 2 of which are a PITA to remove. I'll let you guess which 2 I had to service...
A shop would easily charge $2K for this, while I DIY for < $300. I have a thread in the convertible section about this repair.
