///M3 Forum
Old 01-15-2013, 01:32 PM   #21
gameboy86
My Ride: '02 325i '10 X5 4.8i
http://www.m3forum.net/m3forum/showthread.php?t=190111
Everything you need to know.
gameboy86 is offline   Reply With Quote
Old 01-15-2013, 04:53 PM   #22
NICKBRUM
My Ride: 2004 M3
Originally Posted by taylor192 View Post
Dude, it just depends on the car you get. My car checked out fine, yet in 1 year I have had to fix:
- leaking steering hose
- vanos solenoid
- convertible top hydraulic cylinders
and decided that after 80K miles I should replace:
- RTABs
- FCABs
- end-links
- brake pads front and rear
- shocks
and almost once a year you'll need an oil change.
Thus in my first year I'm out $800 in necessary repairs, and $1100 of maintenance plus my own sweat and tears cause I did everything myself. Double or triple that total if you need a shop. I suspect I'll need a water pump and fan clutch at some point soon, so tack on another $500.
I've spent more on discretionary stuff (grills, lights, springs, diffuser, lip, SSK, wheels, ...) than I have on maintenance.
I have had my car for exactly 11 months purchased with 40k miles, now sitting at 51k. In that time I have done the following.
Alternator
battery
Waterpump
Navigation screen and computer...screen was my fault!
Rtabs
Rear brakes
Oil change
Valve adjustment
spark plugs
Sub frame reinforcement
sub frame bushings
Shocks / springs, and ss brake lines which was my choice to upgrage.
Needing attention but ignored so far.
Broken moon roof sun shade tracks
Bad rear quarter window seals
Weeping steering hose
Probably some other minor BS I'm forgetting.
Some how with all of this I still absolutely love this car, and would not consider anything else in its price range!!
Current:
2006 E46 M3 ZCP silver gray on black SMG
|Stoptech BBK ST40 X 355mm| Style 219 wheels|
|Ceramic coated euro headers| Custom 200 cell section 1|
|TTFS Motor & SMG tune, 315 whp| GC coil overs |
Previous: Totaled
|Carbon Fiber Intake|AA GEN3|AC Strut Brace|Eibach/Koni's|CSL/SMG Flash|
|Victory UDP's|HPF Sub Frame Plates| PF Subframe Bushings|Rtab Limiters|PFC DD Front Rotors|
NICKBRUM is offline   Reply With Quote
Old 01-15-2013, 05:05 PM   #23
s1monove
My Ride: M3 Coupe
Hi, i've had mine for 11 months. It had 25k on it and was mint. I have done 8k miles since and spent the following
2000 in petrol
2 x rear springs 250
4 x brake discs - 400
8l of oil - 56
inspection 2 - 500
4 x tyres - 800
Random expenses - 400
Warranty - 900
Dynavin clone - 600 + fitting
Insurance 650
Madness really as my 330 i had before was perfect and needed nothing doing to it. It was also fully paid for. But i NEEDED an M3 in my life regardless of the expense!!
s1monove is offline   Reply With Quote
Old 01-16-2013, 08:11 PM   #24
JoseRonaldoVargas
My Ride: My feet
Good stuff thanks .
JoseRonaldoVargas is offline   Reply With Quote
Old 01-16-2013, 09:33 PM   #25
m3e46freak
My Ride: m Twee lol
First off, 2500 a year is ****ing ridiculous. LOL that alone makes me want to drive a bike/honda...
I am on my third m3 and I dont think I have spent a total of 3500 on anything for the cars and I changed suspension/oil/fluids/mods/maintenance on all three.
2003 vert
2011 e92
2004 coupe now
Depending on the year, there are plenty of maintenance to do.
60,000 and 100,000 markers are the big ones and then 150,000
So at 60,000 or..whenever you first buy the vehicle all fluids and filters and do plugs/coils, I would do belts also at that point.
Rock Hard Abs Racing
ST Coil!
BREMBO
Apex!
Agency Power Headers!
Euro Cats!
Scorza Mufflers!
FRANK!! 311RWHP-260Torque
m3e46freak@yahoo.com for outside contacting
ebay/craigslist verified 100% FEEDBACK
m3forum 96% FEEDBACK
m3post/e46fanantics Great FEEDBACK
zpost/bimmerforum Great FEEDBACK
m3e46freak is offline   Reply With Quote
Old 01-19-2013, 09:40 PM   #26
Kwipp
My Ride: lsb m3
Originally Posted by S54Dan View Post
I'd say after 100k miles, prepare to spend some money. My M3 went through a bit of a depression in 2012. I track the car a lot so I'm sure I put the parts on more strain, but it would have gone out eventually.
2012 repairs: Fuel pump, fuel filter, RTABs, fan clutch, t-stat, water pump, coolant tank, front brakes complete (pads, rotors, sensor), rear pads, new tires, belts, and all four wheel bearings.
Edit; Forgot to mention inner and outer tie rods, steering column guibo, driveshaft guibo, and center support bearing.
Sounds like normal wear and tear items for that mileage.
Originally Posted by choxor View Post
Go to the e46 section of m3forum.net and read the stickies.
+1000
Dude, you need to ask less and research more. Insurance varies by region, record, age, sex, martial status, ... so asking what others pay is just a shot in the dark unless you can find your twin online, and even then...
Kwipp is offline   Reply With Quote
Old 01-19-2013, 10:22 PM   #27
Steezy
My Ride: 2004 M3
I purchased my car at 98k miles, now at 100k. Replaced CPV valve (oil leak) and exhaust hanger. Wouldn't have known this if I didn't get a PPI. At 98k miles though, RTABS, FCABS, and subframe were all in good shape. I don't know if the PO replaced them or not.
Steezy is offline   Reply With Quote
Old 01-20-2013, 12:23 AM   #28
fatskidmark
My Ride: E46 M3
do this daily:
do this monthly:
do this yearly:
i lol'd...Oh what a rip! It didn't post the last pic?? That was the best part!!
fatskidmark is offline   Reply With Quote
