///M3 Forum
Old 01-14-2013, 07:52 PM   #1
sang
My Ride: S2000
valve adjustment
Hi all~!~
hear that in every 40,000km I have to do valve adjustment
Is this true?
sang is offline   Reply With Quote
Old 01-14-2013, 08:23 PM   #2
eson
My Ride: E46 M3, Porsche 911
Every 15k miles it is recommended to at least check the valves, and if necessary, adjust them.
| '02 LSB slicktop ///M |
StopTech. SGT. AKG. TMS. BimmerWorld. Sparco. Kirk. RE. Enkei. Meisterschaft.
eson is offline   Reply With Quote
Old 01-14-2013, 09:30 PM   #3
sang
My Ride: S2000
So is this only for the M3? or is it for all E46??
Old 01-14-2013, 09:30 PM   #4
turbo_f22_pilot
My Ride: 2 pedals - 2 paddles
You check (inspect the valves) for need of adjustment at every "Inspection" interval (approx 30k miles). You should perform a valve adjustment at Inspection II (approx 60k). The reason for the approxi. tag is, depending on how you drive the car determines how much sooner the service intervals become.
You can check your valves at a more frequent interval of your choosing if you so desire. You can set the lash anywhere within the specs of your choosing if you're performing the work. (some like the tolerances close, some the middle, some on the loose side)
M3 as far as I know, not sure if any regular E46 have similar valvetrain.
In order to finish FIRST, you MUST first FINISH !
Joy is future proof
Get your "M" on . . .
Reading is FundaM3ntal
CAR:
2003 TIAG Coupe / Blk Interior / SMG / HK Premium
MODS:
EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust
Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB
BMWCCA NCC
turbo_f22_pilot is offline   Reply With Quote
Old 01-14-2013, 09:30 PM   #5
NICKBRUM
My Ride: 2004 M3
The inspection interval for the E46 m3 is actually every 30k miles or about 49000km. If you are not sure when the previous owner did it last, you should do in now and go from there.
Current:
2006 E46 M3 ZCP silver gray on black SMG
|Stoptech BBK ST40 X 355mm| Style 219 wheels|
|Ceramic coated euro headers| Custom 200 cell section 1|
|TTFS Motor & SMG tune, 315 whp| GC coil overs |
Previous: Totaled
|Carbon Fiber Intake|AA GEN3|AC Strut Brace|Eibach/Koni's|CSL/SMG Flash|
|Victory UDP's|HPF Sub Frame Plates| PF Subframe Bushings|Rtab Limiters|PFC DD Front Rotors|
NICKBRUM is offline   Reply With Quote
Old 01-15-2013, 09:47 PM   #6
sang
My Ride: S2000
Thank You so much guys~!
Old 01-15-2013, 09:53 PM   #7
$ilent ///M
My Ride: 03.5 M3 smg lsb
Valve adjustment is for the m3 motors only non-m have self adjusting hydraulic lifters.
$ilent ///M is offline   Reply With Quote
Old 01-16-2013, 02:44 PM   #8
lindstrome
My Ride: bmw m3 e46
anyone know if there is a "guide" to do it? i want to do it myself but "BMW" wont give me instructions
lindstrome is offline   Reply With Quote
Old 01-16-2013, 05:43 PM   #9
NICKBRUM
My Ride: 2004 M3
The search function is your friend. Try this forum, M3F has great write ups and don't forget Google. You will want to rent a shim kit and removal/install tool from a forum member. You also need a 32mm or 1-1/4 wrench, as well as a set of calipers or a micrometer.
Current:
Previous: Totaled
Old 01-16-2013, 05:55 PM   #10
Breezy
My Ride: LSB M3, saab 900s
It's fun! Enjoy
Breezy is offline   Reply With Quote
Old 01-20-2013, 10:42 AM   #11
FCBuff
My Ride: 2006 M3 ZCP 2006 X5
Much info out there. I researched it last summer and did it myself. It went fairly smooth. Get the Bentley manual as well. Check out the videos on you tube.
FCBuff is offline   Reply With Quote
Old 01-20-2013, 12:59 PM   #12
m3e46freak
My Ride: m Twee lol
Consult your m3 manual.
Rock Hard Abs Racing
ST Coil!
BREMBO
Apex!
Agency Power Headers!
Euro Cats!
Scorza Mufflers!
FRANK!! 311RWHP-260Torque
m3e46freak@yahoo.com for outside contacting
ebay/craigslist verified 100% FEEDBACK
m3forum 96% FEEDBACK
m3post/e46fanantics Great FEEDBACK
zpost/bimmerforum Great FEEDBACK
m3e46freak is offline   Reply With Quote
Old 01-20-2013, 01:07 PM   #13
kuksul08
My Ride: M3
Check out the link in my sig. There is a DIY, spreadsheet, and TIS that may be helpful.
Look at that subtle jet-black coloring. The tasteful thickness of it. Oh my God, it even has a 6mt.
S54 Valve Adjustment Spreadsheet & Info: http://dl.dropbox.com/u/28231781/S54...ent%20info.zip
S54 VANOS DIY Video: http://www.youtube.com/watch?v=9SkT2j3jsU0
kuksul08 is offline   Reply With Quote
Old 01-21-2013, 10:30 PM   #14
emax
My Ride: 06 M3
A bunch of good videos on youtuber...here is one of my favs...part 1
'06 CB/IR w/SMG/NAV/HK/19" BBS RGR/Hankooks
emax is offline   Reply With Quote
