Sponsored by The Tire Rack
Old 01-14-2013, 09:29 PM   #1
Hoyshel
My Ride: 330ci
Tire shop installed wrong size tires
So I got four new Continental DWS tires installed on my 2001 BMW 330ci about 6 months ago and just got a nail in one. I took it to a different shop from where I purchased the tires and they pointed out to me that all 4 tires on my car are 245/40R-17. They're supposed to be staggered with 225/45R-17 up front and 245/40R-17 in the rear. When I got my tires installed i just told them to put 4 new tires on. I assumed they knew that they weren't all the same size. On my receipt it says 225's up front and 245's in the rear. Afterall, it says it on the inside of my door jam, that's what was on the car when they replaced them, and that's what should have come up in their computer system. On top of everything, I have taken my car back to that same shop twice since I purchased the tires for a tire repair and alignment and they didn't say anything about it. Also, are there any negative ramifications to driving around with with 245's in terms of worn suspension components, etc?
Would you expect the shop to replace the front 245's with 225's at no charge?
Hoyshel is offline   Reply With Quote
Old 01-14-2013, 10:40 PM   #2
ZeeZoo
My Ride: '99 323i
I would say it's both the shops fault and a little bit of fault on your end. You drove on those tires for 6 months and I wouldn't be surprised if they refused to changed the front tires to 225. If anything, they should give you a discount on your next tire change but you should've double checked that they were the wrong size when they were installed. I had this happen to me once when a Mavis put one tire a different size than the other 3 but not 6 months after.
As for the suspension, I don't think anything major could happen as long as your fronts were aligned.
ZeeZoo is offline   Reply With Quote
Old 01-14-2013, 10:54 PM   #3
Hoyshel
My Ride: 330ci
I agree, I should have checked before leaving. However, they are the "experts" and I trusted that they would install the correct tires. There are parts on cars that are visible after installation and parts that aren't. If a shop said that they installed an OEM fuel pump would you pull out the back seat and check yourself? And if you did and found that it was not OEM would you not return to the shop, no matter how long it had been, and expect the pump to be replaced with an actual OEM pump?
Old 01-14-2013, 10:59 PM   #4
SD 328I
My Ride: S197, E90, and 1125R
Regardless of how long you went without noticing (which is pretty long), they did install the wrong tires as per your receipt, I expect them to help you out. At the very least, they should give you some depreciated value since you did use those tires for so long.
SD 328I is offline   Reply With Quote
Old 01-15-2013, 12:06 AM   #5
tnhl1989
My Ride: 02 330xi(RIP),03 ZHP
DWS has 1 year round hazard warranty as well. I wouldn't say wrench they on purpose however I had a set replaced because of a bunch of air bubbles. Had to put to remount them but better than buying a new set of tires.
tnhl1989 is offline   Reply With Quote
Old 01-15-2013, 12:09 AM   #6
rcsummers
My Ride: M3
well a square setup handles better. and you payed for 225s in the front. its technically a win-win. Right?
"RICH"
My Build Thread
EURO.TECHNIKS
- Status Gruppe Tuning - Broadway Static - Recaro - DTM Fiberwerkz - AutoCouture Motoring -
Instagram: @summers_e46_m3
Twitter: @rcsummers0506
Xbox One: MisterMeisterM3
rcsummers is offline   Reply With Quote
Old 01-15-2013, 03:03 PM   #7
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Your receipt says one thing, but if you waited this long the shop doesn't know if you swapped them out with the larger size in the meantime, even if you are being truthful. So it's kind of a tough situation. I don't think you have much to worry about though if it's not rubbing on anything. If it took you this long to notice it can't be that bad haha.
That's one way to look at it!
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 01-15-2013, 05:12 PM   #8
Riverbmr3
My Ride: MB E350 & BMW 325i
The wider the better, just use it.
Riverbmr3 is offline   Reply With Quote
Old 01-15-2013, 05:15 PM   #9
Rudy540
My Ride: E46
Keep em
Rudy540 is offline   Reply With Quote
Old 01-15-2013, 05:47 PM   #10
rcsummers
My Ride: M3
Originally Posted by Rudy540 View Post
Wider tires at back for traction, thinner tires up front for better turning, and cornering
So no, maybe not all a win win but not a loss either
you make no sense. square set ups handle better than staggered. pretty sure almost everyone on here will agree. wider tires in the front means a wider contact patch resulting in more grip.
"RICH"
My Build Thread
EURO.TECHNIKS
Old 01-15-2013, 05:51 PM   #11
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
Lol what?
This makes NO sense.
Old 01-15-2013, 05:58 PM   #12
jerseyzillest
My Ride: 325 CI
By the way no your suspension and everything else is fine. since no one answered that question
Photobucket
^Taken with iPhone^
:rofl:
jerseyzillest is offline   Reply With Quote
Old 01-15-2013, 06:49 PM   #13
Rudy540
My Ride: E46
Can any one temm why staggered wheels typically mean wider/bigger in diameter tires at back than the front ones, apart from looks?????
Old 01-15-2013, 06:55 PM   #14
rcsummers
My Ride: M3
Can any of you two little smart asses ^^ tell me why did bmw engineers decide to define staggered wheels typically meaning wider/bigger in diameter tires at back than the front ones, apart from looks?????
Hmmmm if putting wider tires all the way around would be better on the track why doesn't everyone do it.
Front tires do the turning meaning that less tire width easier and better turning angles, rear do all the pushing so wider means better traction
nice language..... and we could debate about this all day. but i dont want to waste my time. so go ahead, make a poll and ask the great people of e46fanatics what they think handles better. Staggered or Squared. Or even better, ask all the track rats over on M3Forum. They'll all say the same thing too. You'd be amazed by the results.
most people who track their cars on here use square setups. just ask....
"RICH"
My Build Thread
EURO.TECHNIKS
Old 01-15-2013, 07:03 PM   #15
peytonracer4
:D
My Ride: '00 328i
Bmw did it for looks. It looks really sexy and that's why I have it staggered on my car. Our cars do not put down enough power to benefit from running anything wider than 235 in the rear. M3s do.
Also, square setups do provide more grip on the track, and pretty much every does do it, smart ass.
245s in the front are absolutely not going to restrict your steering angle and a car with 245 in the front versus a car with 245 in the front will feel the same in normal driving conditions. It will not make steering any different.
You really need to study up on driving dynamics and what causes a car to handle with understeer, oversteer, or to be neutral. You simply don't know what you're talking about. More rubber=more contact patch=more grip.
Do a little studying of driving dynamics, physics, and common sense before you come in here throwing around insults and making yourself look like a fool.
There's a reason I can consistently place in the driving events I partake in. And using thinner tires for "better turning" is not a strategy I use
Old 01-15-2013, 07:05 PM   #16
trj
My Ride: 325Ci
OP since its been so long the shop most like wont give you the new correct size tires.
However, you paid less for wider tires so you win here.
Now for the staggered fitment discussion, BMW Chose wider tires in the rears for better traction which in turn results in slight under steer. Also looks better I must add.
The turning radius is directly proportional to the tire diameter though. Smaller the diameter smaller the turning radius. The width of the tire does minimal to the handling unless you are talking about out of whack wide tires.
As long as you are within the specs you are good.
OP, you have an advantage of rotating tires now(not the wheels). Just make sure you are running wider wheels in the rear though.
Old 01-15-2013, 07:29 PM   #17
Rudy540
My Ride: E46
Blank
Old 01-15-2013, 07:32 PM   #18
Rudy540
My Ride: E46
Why didn't u explain urself in the first place
