Warning light, Brake Pads? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 01-14-2013, 10:51 PM   #1
Cubbie4109
My Ride: 05 325xi
Send a message via AIM to Cubbie4109
Hello,
The warning light on the picture came on my '05 325xi. Initial research says it might be the brake pads. Brakes were done in March of this past year 2012, Brakes feel fine but I rather not take a chance. Any idea what I need to be looking for? Please Advise. Thank you for your help in advance.
Cubbie4109 is offline   Reply With Quote
Old 01-14-2013, 11:47 PM   #2
Kubica
My Ride: 2003 325xi
One of the brake sensors was tripped due to low pad life left or the sensor itself was damaged.
Did you have both front and rear brakes done? If not its probably time to have the other set done.
Old 01-19-2013, 07:42 AM   #3
My325XI
My Ride: 03 325XI Sprt Prem
+1 ^^
2003 325XI 5-speed ZSP ZPP
My325XI is offline   Reply With Quote
Old 01-19-2013, 07:53 AM   #4
limpiabota809
My Ride: 330 XI
^ He ain't lying
Instagram - @Limpiabota_e46
limpiabota809 is offline   Reply With Quote
Old 01-19-2013, 02:36 PM   #5
Dreamliner330
My Ride: 330xi
Sensors are on Front/Driver Side & Rear/Passenger Side. Pull off wheel and inspect pad thickness. New is ~.5" thick.
Kubica is right, as usual. Check your invoice to see what was specifically done.
Dreamliner330 is offline   Reply With Quote
Old 10-26-2013, 03:48 PM   #6
BMWAddict
My Ride: 99 323i
On my X3, the brake pad light stayed on for a week while I compared prices for the parts for a DIY-project or a local non-BMW auto repair since my the dealer quoted me $808(ft) and $776(bk). I estimated all the parts would be 374-625 (rotors,pads,senors,hold-on bolts) depending on OEM or drill-slot rotors/ceramic-carbon pads. Then the 'low-tire pressure' light came on yesterday. I measured the tires and found they were all about 25 psi and filled to 34-38 using my electronic air pump. To my surprise, both the low-pressure and brake-pad lights turned off. The weather has recently dipped down to nightly lows of mid-30s to 40s which may affect the tire pressure. I will inspect the pads to see how much leeway the idiot light gives me to decide if the brake work will be an immediate or 'next-year' project.
76 '02 and 99 323i
BMWAddict is offline   Reply With Quote
