Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Complete Cars - Private
Old 01-15-2013, 12:14 AM   #1
wsybert
My Ride: E46 M3 Vert
FS: 1999 E46 328i track car
Mileage: 163,xxx, Price: $7,000
Not looking to trade.
Modifications:
*Kirk 4 point bolt in cage
*RTAB, LCA, Trans mount, and Rear subframe bushings are all Powerflex urethane
*Myele HD LCA's
*Subframe reinforced with Turner kit. No cracks prior to installation.
*Ground Control coil over suspension. Street / track setup.
*440#/in. front and 550#/in. rear. The shocks are Koni yellow adj.
*Ground Control front monoball camber plates and rear adj camber arms.
The car is currently set up with -2.5 deg. front camber and -1.5 deg. rear camber.
*Kuhmo Ecsta XS tires, 245-40-17 all around.
*Kosei K1 wheels, 17x8.5 (16.5# each)
*UUC adjustable swaybars front and rear. Custom reinforced rear bushing mounts. Both front and rear have urethane bushings.
*UUC Short shift kit with DSSR. Delrin weighted shift knob.
*Conforti cold air intake.
*Hawk HT-10 pads front and rear with stainless brake lines and brass caliper bushings.
*2.5 # extinguisher
*10" panoramic mirror.
*OMP aluminum race pedals.
*Momo mod 78 330mm suede wheel. Horn works.
*Sunroof cartridge replaced with carbon fiber panel.
*Recaro Proracer SPG driver seat. The seat is on fixed rails, so some modification would be needed to move it, if required. I am 5'-10" 200# for reference. I believe there is a little adjustment possible with the brackets.
*Corbeau F1 Passenger seat. Fixed seat, but will accommodate most people.
*5 point Simpson 3" camlock harnesses on both sides.
*Full A/C delete (no bracket, compressor, evap, or condenser)
*Magnaflow stainless 4" muffler. Only muffler was replaced, remaining OE exhaust is intact.
*The only interior left, is the front door panels, dash, and shift console. No carpet, rear door panels, headliner, rear deck, or trunk lining.
*Replaced plugs and valve cover gasket in Oct 2008 right after I bought it.
*Power steering lines replaced in Oct 2008 with new.
*New serpentine belt and idler installed in Oct 2008
*All coolant lines replaced in Oct 2008 with new, along with 180 deg. thermostat.
*New Stewart high performance metal impeller water pump installed in Dec 2008.
*New ATE rotors front and rear, Oct 2008.
Pretty much all the above was done in late 2008 and over the winter into 2009, and only driven approximately 1200 miles since then.
I bought the car in October 2008 with 161,xxx miles on it. I initially drove it for a couple of weeks and then started the track build. This car is street legal, as I initially drove it to the track. It has been trailered for the past two years, for convenience. Currently it is not registered and has no insurance or plate. I figured why with the trailer.
The car is in storage now, in a climate controlled facility, and when not there, it is in my garage. I have only put about 1200 miles on the car since purchase. I don't know the exact mileage, but it is right around 163k. I have run 17 track days over the past 4 years and the car has been extremely reliable. The only issue I've had was a bad battery, which was just replaced this summer.
The oil is changed every season and the entire brake system is flushed with performance fluid like ATE Super Blue or Wilwood EXP 600+. Additionally I go through the car thoroughly before every track weekend, and check for any issues, leaks, cracks, etc... nothing to note to date.
I have an extra set of front Hawk HT-10 pads. These pads are a perfect fit for the speed and weight of this car. No fade and great initial bite and feedback. The brake system is stock and is more than adequate with the Hawk pads. I also have a full spare tire, Kuhmo Ecsta XS 245-40-17. Not mounted.
There is NO A/C, Radio, speakers, airbags (except for side front in door panel. Just haven't bothered to take them out, but the controller is gone.), the trip reset button doesn't work on gauge cluster, but you can cycle through the computer with the stalk.
Power windows, power locks, lights (head and tail), turn signals, horn, wipers (no rain sensing), washer jets, heater and climate control, and gauges all work fine.
The ABS and DSC work. The DSC can be turned off with the button.
To say the least, the car is raw. Runs great and starts on the first crank out of storage. Burns and leaks NO oil and idles like it was new.
I am active on XBimmers and Xoutpost currently. I have history on E90Post and a good iTrader rating there. All under the name, wsybert.
The pictures with the stripes are the most recent. They were taken at Nelson Ledges in Ohio last year, and the one on the trailer in my driveway was before that trip. (The stripes were done with plastidip, so they will come off if it's not your thing.)
I feel the asking price is a good starting point for a complete, well sorted, fun and safe track car, that needs nothing to go to a track day event. I am open to offers and I don't need to sell it, so I am not giving it away. I am selling because I don't use it that much anymore. Two track weekends last year and one the year prior.
I think I covered it all.... nothing like being thorough.
Thanks for looking.
Bill
Name:	Nelsen Ledges1a.jpg
ID:	486122   Click image for larger version
Name:	Nelsen Ledges2a.jpg
ID:	486123   Click image for larger version
ID:	486124   Click image for larger version
ID:	486126   Click image for larger version
Name:	Track car stripes1.jpg
ID:	486127   Click image for larger version
ID:	486128   Click image for larger version
ID:	486133   Click image for larger version
ID:	486134   Click image for larger version
wsybert is offline   Reply With Quote
Old 01-15-2013, 12:29 AM   #2
taveet330i
My Ride: Jet Black 2002 330i
Is she street legal? Just wondering. GLWS my friend. Very nice car and some great mods
Dedication
_______________
Dedication
2002 Jet Black 330i|ZPP|Hellbeige interior|Carbon Fiber Interior Trim|Alzor 703 CSL Reps|Custom Flowmaster Catback Exhaust|LED Halo Rings|Black ECSTuning Kidney Grilles|Eonon D5150|
taveet330i is offline   Reply With Quote
Old 01-15-2013, 07:58 AM   #3
wsybert
Dedication
Yes. At least where I live it is.
Horn, signals, ebrake, lights, gauges all work. As do most of the convenience features... Power windows, locks, abs, dsc, and cruise.
Thanks.
Bill
Old 01-15-2013, 09:28 AM   #4
EmDeeAr
My Ride: 330i ZHP
Looks really fun to drive. E46 track cars always look sweet. GL!
EmDeeAr is offline   Reply With Quote
Old 01-18-2013, 06:26 PM   #5
wsybert
Bump.
Old 01-25-2013, 01:21 PM   #6
wsybert
Weekend bump.
Old 02-02-2013, 04:36 PM   #7
wsybert
Bump
Old 02-09-2013, 08:14 PM   #8
wsybert
Price updated.
Old 02-10-2013, 08:28 PM   #9
snow325
My Ride: 325i
This is a great price. GLWS
snow325 is offline   Reply With Quote
Old 02-12-2013, 11:21 PM   #10
wsybert
Thanks. Open to reasonable offers.
Bill
Old 02-13-2013, 07:44 AM   #11
vorceb23
My Ride: 04 330i
that x5..... glws
R.G.V. 1929-2013 Forever Loved
vorceb23 is offline   Reply With Quote
Old 02-21-2013, 08:46 PM   #12
jhstealth
My Ride: 323is,740i(S),gt86
Are those corbeau's FIAA approved?
Fs: 06 z4 M coupe imola on black
jhstealth is offline   Reply With Quote
Old 02-21-2013, 09:43 PM   #13
wsybert
Only the passenger seat is Corbeau. Not sure of its certification.
The driver seat is a Recaro Proracer SPG and is an FIA certified seat. Not sure of its age however.
Old 02-22-2013, 06:55 AM   #14
Andy2108
My Ride: SpecE46 & E46 M3
Nice! I like it.
I have a friend who may be interested. Have you ever dynoed the car or weighed it?
De gustibus non est disputandum.
Old 02-22-2013, 07:55 AM   #15
wsybert
Originally Posted by Andy2108 View Post
Nice! I like it.
No dyno or weight check. Engine is pretty much stock, except for Conforti CAI, and rear muffler replaced with a Magnaflow unit.
Thanks and let me know.
Old 03-25-2013, 09:34 PM   #16
wsybert
Bump. Warm weather is coming....(even though we just got 3" of snow).
Old 03-30-2013, 05:16 PM   #17
wsybert
Bump.
Old 04-05-2013, 12:19 AM   #18
wsybert
Lets talk numbers.
Old 04-22-2013, 10:57 PM   #19
wsybert
Bump.
Old 04-22-2013, 11:25 PM   #20
AudiEtr
My Ride: 330i
If I wasn't getting married soon, this would be at my house already. I get married in sept, if you still have it I will be highly interested!!
AudiEtr is offline   Reply With Quote
