Sponsored by The Tire Rack
Old 01-15-2013, 02:40 AM   #1
wernerp
My Ride: 2001 bmw 330d auto
Exclamation traction control light and handbrake light
Hi guys can someone give me advise i swapped my 2001 bmw 330d's tyres around and after getting on the freeway my traction control light came on as well as the handbrake light in yellow i tried disconnecting the battery for a couple of days but the problem stayed what could have caused it ? could it be a dirty wheel sensor or alignment a noticed the alignment is out at the moment and the car tends to pull left and the steering wheel is not in the center when driving strait
wernerp is offline   Reply With Quote
Old 01-15-2013, 09:38 AM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Did you rotate the tires and the thread is facing the wrong direction?
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 01-16-2013, 08:22 AM   #3
wernerp
that's exactly what i did how stupid of me could that be the problem
Old 01-16-2013, 11:51 AM   #4
wernerp
I changed the tyres back to original positions and also took out the wheel sensors and gave them a good clean while the wheels was off . Then i went for a quick drive on the freeway but still no luck the lights stayed on. Any suggestions?
