Old 01-15-2013, 09:48 AM   #1
Jgmacho
My Ride: 325i
Aftermarket fuel filter and regulator install on 325i
Car has new fuel pump. Original fuel pump was failing on initial engine starts. Installed an Aeromotive fuel pump and is currently overrunning OEM FPR. Converting stock system with AEM regulator and Holley inline fuel filter. Putting fuel system back to stock fuel pressure and will meet the needs of my supercharged engine. Will post pictures when my install is complete
Jgmacho is offline   Reply With Quote
Old 02-24-2013, 04:05 AM   #2
Edgar3498
My Ride: 330CI
Pics
Sent from my SGH-T999 using Bimmer App
Edgar3498 is offline   Reply With Quote
Old 02-28-2013, 08:08 PM   #3
Jgmacho
My Ride: 325i
Well I guess this is not really a DIY but it is fairly simple. I removed the stock system and ran my own braided hosed lines. On this particular regulator I found out the hard way that the return line to the tank is on the bottom. The manufacturer ,AEM, calls it the output line. Well I got confused. I ended up using the silver flow nut that came with the regulator. It came with three black, silver, and gold. Gold is the biggest. It can be adjusted to over 100 psi. I kept it at 50-54 psi. I liked this regulator because it it regulates my aero motive pump. My stock one didn't. For the parts that are hard fuel lines I clamped a barbed -6an fitting using a rubber fuel hose. That allowed me to use my braided fuel lines. On one pic of my fuel rail you can see that set up. I ended up using a smaller length filter because any bigger than stock you couldn't put splash guard on. Car runs excellent. My fuel pressure is right on with stock specs.
ID:	493126   Click image for larger version
ID:	493127   Click image for larger version
ID:	493128   Click image for larger version
fpr, fuel, fuel filter, pressure, regulator
