///M3 Forum
Old 01-15-2013, 10:52 AM   #1
his15153
My Ride: 2001 BMW M3
Engine vibration and intermittent roughness
I recently cleaned the ICV valve. After I had reinstalled everything, it had turned out that the new hose clamps I had installed caused the intake control arm (I'm not sure the exact name of it, but it is what opens and closes the intake) to come loose. I figured it out and changed the angle. But anyways, after this I drove the car about 50 miles round trip. During the first portion of the drive, everything ran smooth. When I left to come home, I noticed the car had a very slight vibration. It wasn't there before (and since then I sat in another M3 and it definitely did not have it either, so I know its not in my head). Also, shortly after the engine started running rough. You felt it while idling and also while accelerating.
The next morning, the vibration was still there, but the roughness had gone. Now the roughness intermittently comes back. I am not sure what could cause this. Originally I thought one of the spark plugs might be fouled, due the car running rich for that little bit while the intake stayed closed. I took the plugs out and inspected them and they didn't look dirty. So now, I'm not sure what this could be.
his15153 is offline   Reply With Quote
Old 01-15-2013, 05:28 PM   #2
scca_ziptie
My Ride: 2006 M3 SMG Comp pkg
Sounds like a vacuum leak. You sure you got all hoses reinstalled correctly (if removed) and that everything is tightened securely?
"! First rule of Italian driving, that which is in your mirror is not important !"
scca_ziptie is offline   Reply With Quote
Old 01-15-2013, 08:58 PM   #3
$ilent ///M
My Ride: 03.5 M3 smg lsb
May need to drive some more so the dme can relearn the adaptations since you cleaned the icv.
$ilent ///M is offline   Reply With Quote
Old 01-17-2013, 12:36 PM   #4
his15153
I checked all the hoses, and they all seem to be installed properly and tight. As for the DME, is there anyway to reset it?
I also just did a smoke test, and there are definitely no vacuum leaks.
Old 05-23-2013, 10:00 AM   #5
his15153
So I recently took the car to 2 different mechanics. They have both given me different opinions on what is wrong.
I do get an intermittent check engine light for the catalytic converter. However, the roughness happens with or without that light being on. But one mechanic thinks that may be the problem.
The other mechanic told me that it could be the flywheel. In which case, maybe the problem I am having is not roughness, but just a vibration.
Has anyone had this same problem. Both jobs will end up being pricey, so I hate to do either one on just a whim.
