Old 01-16-2013, 01:59 PM   #21
Blackbeamer00
My Ride: BMW 323i 2000
Originally Posted by CarterRuss View Post
Here is my thread on my issue: http://forum.e46fanatics.com/showthr...067&highlight=
The wheel bearing/hub DIY: http://forum.e46fanatics.com/showthread.php?t=610725
When you go to put the wheel hub on the spindle, you need to use a bearing race installer. I used a 36mm socket the first time around and damaged the bearing (specifically the bearing holder). The socket puts force on just the inner race, where as the race installer puts equal force on both inner and outer race causing the bearing to move onto the spindle as a whole. You only use the socket to finish securing the hub after, I missed that note in the DIY the first time around
If you look at your wheel hub and it looks like grease or oil is seeping out of the bearing, it is most likely damaged, or if you can wiggle the hub and notice movement. The problem with the hub is that once it is one there, you can't take it off unless you plan to replace.
if change that with this would it fix the problem?
Blackbeamer00 is offline   Reply With Quote
Old 01-16-2013, 02:00 PM   #22
Blackbeamer00
if change that with this would it fix the problem? cuz it would be better then getttin a new hub plus a rotor and brakes?
noise, wheel
