General Off-Topic
Old 01-15-2013, 05:39 PM   #1
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
CS Guys - Help me out really quick
This is some python code but I fugure the loop logic should be the same in all languages. I'm using this function to plot decay:
100e-t/5
And I need it to step through 1 second intervals 0-->5 and plot the result. I'm sending the results to a 1D array. The array and plotting are working fine but for some reason it's not calculating correctly.
Code:
for j in range(6):
	num2[j] = n2
	n2 = 100*e**(-j/5)
And this is the array that it spits out. I have no clue why it repeats 100 and then jumps down to 36.
Code:
[ 100.          100.           36.78794412   36.78794412   36.78794412    36.78794412]
Old 01-15-2013, 05:41 PM   #2
Treburkulosis
My Ride: BMW
about 350
Treburkulosis is offline   Reply With Quote
Old 01-15-2013, 05:43 PM   #3
kuksul08
My Ride: M3
Terrorists win.
Look at that subtle jet-black coloring. The tasteful thickness of it. Oh my God, it even has a 6mt.
S54 Valve Adjustment Spreadsheet & Info: http://dl.dropbox.com/u/28231781/S54...ent%20info.zip
S54 VANOS DIY Video: http://www.youtube.com/watch?v=9SkT2j3jsU0
kuksul08 is online now   Reply With Quote
Old 01-15-2013, 05:48 PM   #4
NOVAbimmer
My Ride: E60M
42
NOVAbimmer is offline   Reply With Quote
Old 01-15-2013, 06:16 PM   #5
bioman
My Ride: is fast.
Is n2's initial value 100? When you calculate n2 for the first loop, you're basically doing 100*1.
bioman is offline   Reply With Quote
Old 01-15-2013, 07:00 PM   #6
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
Yeah. And that's correct, at t=0, n2=100. But at t=1, it should be 81.87
edit: Messing with j just shifts the array but still gives the wrong answers. I know it's a simple fix but for whatever reason I'm not seeing it
Old 01-15-2013, 08:09 PM   #7
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
Ok so something is wrong with the math, not sure why it's doing this
Old 01-15-2013, 09:59 PM   #8
dreamdrivedrift
My Ride: 99 M3 & 95 325i
Send a message via AIM to dreamdrivedrift
didn't really look closely but it looks like you inputted the array value before you actually calculated n2
Chris
dreamdrivedrift is offline   Reply With Quote
Old 01-15-2013, 10:19 PM   #9
nikkeiS2K
My Ride: N/A
Send a message via ICQ to nikkeiS2K Send a message via AIM to nikkeiS2K Send a message via MSN to nikkeiS2K Send a message via Yahoo to nikkeiS2K
Try using parenthesis.
Does the exp() function work the same way as e**?
I see you have it two different ways.
nikkeiS2K is offline   Reply With Quote
Old 01-15-2013, 10:23 PM   #10
mistrzmiasta
My Ride: GLK350,ML63, Duc1098
just use science.
mistrzmiasta is offline   Reply With Quote
Old 01-15-2013, 10:28 PM   #11
bimmerfan08
My Ride: F
You're a civil engineer :p
"You are free to make choices. You are not free to escape the consequences."
bimmerfan08 is offline   Reply With Quote
Old 01-15-2013, 10:41 PM   #12
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
I need to set everything in the exp(), or e**, function as a floating point instead of an integer. That was the problem
Old 01-28-2013, 06:36 PM   #13
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
I'm at a loss here. It keeps telling me I'm using invalid sytanx when delcaring density. I've tried changing the variable name, tried commenting out the else/elif statements even though they work fine, tried putting the equation to the right of it in parentheses, but it keeps telling me the same thing. All I want to do is test to be sure the equation is correct
Code:
height = raw_input('Fall height (meters): ')
height = float(height)
t_0 = 288.15 	# Air temperature (degrees kelvin) at sea level
L = 0.0065 	# Temperature lapse rate (degrees kelvin / m)
R = 287.058
g = 9.80665
R2 = 8.31432
m = 0.0289644
p_0 = 101325
t_0 = 273.15
Lb = -0.0065
power = (g*m)/(R2*Lb)
temp = 271
if (0.0<=height<100):
	temp = 100
elif (100<=height<200):
	temp = 200
elif (200<=height<300):
	temp = 300
elif (300<=height):
	temp = 400
pressure = p_0*(t_0/(t_0-Lb*(height))**power
density = pressure/(R*temp)
print(temp)
print(pressure)
print(density)
Old 01-28-2013, 06:39 PM   #14
VaderDave
Invictus
VaderDave's Avatar
My Ride: 330CiC ZHP
I'm not sure what any of this has to do with customer service.
VaderDave is offline   Reply With Quote
Old 01-28-2013, 06:45 PM   #15
Spiral Prophet
Über-Geek
Spiral  Prophet's Avatar
My Ride: '01 Topaz Blue 330ci
Send a message via AIM to Spiral  Prophet
The invalid syntax isn't with the density equation.. it's with the line previous.. you're missing a ) in the formula.. you have 3 ( and only 2 )
Python tends to report an invalid syntax at the line after the actual problem
Spiral  Prophet is offline   Reply With Quote
Old 01-28-2013, 06:48 PM   #16
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
This is why I will never code for a living. Small sh!t like this drives me nuts. Thanks.
Old 01-28-2013, 06:56 PM   #17
Spiral Prophet
Über-Geek
not a problem.
Just remember that debuggers are smart but also really dumb.. if it points to something as an error.. the chance of the error being the previous line is just as good as it being where it's pointing.
Coding all day is relaxing as hell..
however coding for micros is in itself a whole other level of hell.. That's what i do all day.
Old 01-28-2013, 07:03 PM   #18
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
It's too tedious for me, I need action. Although I'll admit that when everything works well it does feel good.
Old 01-28-2013, 07:05 PM   #19
v8 5
My Ride: 6 speed BMW
Originally Posted by kuksul08 View Post
Terrorists win.
Gutted with a Getrag
We have 4 websites within the family.
v8 5 is offline   Reply With Quote
Old 01-28-2013, 08:10 PM   #20
Grande D
My Ride: E36 M3
I HATE Python.
It will change your life!
