General Off-Topic
Old 01-28-2013, 08:24 PM   #21
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
I figured it out.
Ok, one last problem. I need to pull the max value from two arrays and compare them. I've tried
Code:
max(sound) = s_max
Where sound is the array I'm pulling from but it doesn't work. It pulls values, but not the correct ones. I've also tried
cowmoo32 is online now   Reply With Quote
Old 01-28-2013, 08:47 PM   #22
Saintluk2
My Ride: 2000 323i sedan
max_fps 200
Saintluk2 is offline   Reply With Quote
Old 01-28-2013, 08:52 PM   #23
v8 5
My Ride: 6 speed BMW
cmd_rate 15000
cl_updaterate 15000
Gutted with a Getrag
We have 4 websites within the family.
v8 5 is offline   Reply With Quote
Old 03-17-2013, 11:34 AM   #24
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
Ok, who knows arrays?
I have two arrays, 1D and 2D. I need to plot plot the 1D on the X axis and the rows of the 2D on the Y. So for every X value, I have a row in the 2D array that should be plotted in the Y. I can plot the 1D against a single value from the 2D, but I keep getting a dimensional mismatch error when I try to plot the entire row against the 1D, and I'm not sure why.
Here I'm trying to plot a single row against the 1D array, the end goal plotting every row against every value in the 1D array.
Code:
plot(drive_force[0:j],theta[2,0:n])
drive_force is 1 x j and theta is n x j. Would it work if I transposed theta to j x n?
Old 03-17-2013, 12:45 PM   #25
Redline
Redline's Avatar
My Ride: ///M3 Vert
I can't math
k.
///M
Old 03-17-2013, 12:47 PM   #26
nikkeiS2K
My Ride: N/A
Send a message via ICQ to nikkeiS2K Send a message via AIM to nikkeiS2K Send a message via MSN to nikkeiS2K Send a message via Yahoo to nikkeiS2K
you need a nested for loop
nikkeiS2K is offline   Reply With Quote
Old 04-27-2013, 10:18 AM   #27
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
edit: Igore that, I figured it out.
So let's say I have a 2D array filled with integers of either 1 or -1. How could I assign each value a color and plot the array? For example, -1==blue, 1==red and I want to plot them as a grid showing the value of each point in the array.
Old 04-27-2013, 10:27 AM   #28
So Lowww
My Ride: E36M
Came in for the Counter Strike, saw math and almost shot myself
S T A N C E | W O R K S
So Lowww is offline   Reply With Quote
Old 04-27-2013, 11:52 AM   #29
z00
Banned User
My Ride: E46 M3 Manual
Iterate over each element of the array and assign a color, then plot the array. What's the problem?
z00 is offline   Reply With Quote
Old 04-27-2013, 10:31 PM   #30
nikkeiS2K
My Ride: N/A
First you need to iterate through the 2D array then you can either a) determine what element you are looking at and plot it as a certain color or b) assign each element a color value and then plot them.
Old 04-27-2013, 10:37 PM   #31
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
It was a lot easier than that. Python has a function that does it automatically
If any of you are interested, I'm running the Ising model on a 100x100 lattice and investigating how magnetizing certain parts of the grid affects the overall energy & mangetization
