Old 01-15-2013, 07:00 PM   #1
Whig Bong
My Ride: 2001 BMW 330ci
Brake fluid leaking from bottom of transmission bell housing (x-posted from S&B)
So the other night I was driving home and my clutch pedal went out. I've had my master cylinder and my slave cylinder go out on my E30 before and I knew what it felt like so I decided to tow the car home and replace the slave cylinder. Got the new slave cylinder installed in about an hour and tried to bleed it. Only problem was when we added brake fluid to the reservoir it wouldnt hold the fluid. I check for any holes in the reservoir and couldnt find any. Then we pushed on the break pedal to see if there was a leak in the master. A ton of brake fluid started dripping from the transmission access panel and I got underneath and all I could see was fluid leaking from the bell housing. I know the brake lines that go over to the DSC unit run over the top of that section but can brake pipe even leak like that?
Thanks in advance,
Whig Bong
TL;DR: when I press brake pedal fluid leaks from bottom of bell housing. Think it has to do with DSC
Whig Bong is offline   Reply With Quote
Old 01-17-2013, 10:10 AM   #2
teamdfl
Slow in, slower out
My Ride: 325it
The slave is leaking fluid into the bellhousing. If the slave was not properly installed with its pushrod on the release fork, you pushed the slave cylinder piston out of its bore. Get another Slave cylinder.
Mod the driver. Participate in your local BMWCCA autocross or driving school. Have you joined BMWCCA yet?
teamdfl is offline   Reply With Quote
Old 01-21-2013, 11:13 AM   #3
Whig Bong
Took the slave cylinder off and this was exactly the problem. Thanks for the help. Any tips for making sure this doesn't happen when I put another new one on?
Old 01-25-2013, 10:19 AM   #4
teamdfl
Slow in, slower out
My Ride: 325it
It's been a while since I replaced one on an E46 so I don't remember any tricks or problems. In general, I bleed BMW slave cylinders by hand while under the car. With the slave hooked up to its hose but not installed in the trans, orient the slave so the hose fitting is up. Slowly push the pushrod in and let it extend a few dozen times. The air goes up and out the line and gravity pulls fluid down into the slave. Top off the brake fluid reservoir frequently to avoid pulling air into the line. When it feels and sounds like no more air is in the slave, bolt it in.
Old 01-25-2013, 03:37 PM   #5
can0n4
My Ride: '04 330xi, '04 X3
just make sure it goes in straight. I did the same thing. Ten minutes later after I got the rod back in the slave cylinder I put it in straight and it was fine.
can0n4 is offline   Reply With Quote
Old 01-25-2013, 08:12 PM   #6
Whig Bong
Update: There turns out to be a lot more wrong with the system than I thought. Sent it to a local shop for further work
