Old 01-15-2013, 08:10 PM   #1
bwh3200
My Ride: 2003 325i, 2006 M3
SRS Code Reset
Does anyone in the Richmond VA area have a SRS code clearing tool? I dummied up and set the code while replacing the window regulator. BMW wants to bust me in the ass of course. The car is a 03 325i. Thanks, Barry!
bwh3200 is offline   Reply With Quote
Old 01-15-2013, 09:33 PM   #2
shovelit
My Ride: 03 325xi and 04 330x
drop the $34.00 on PA soft.
shovelit is offline   Reply With Quote
Old 01-15-2013, 09:35 PM   #3
zhenkaaaM3
My Ride: Fst'r then your e46
SRS is the airbag light, correct? If it is, then it wont come off with the PA soft. Been there done that. Theres a special scanner for that.
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 01-16-2013, 07:31 PM   #4
bwh3200
http://www.greebid.com/wholesale/bmw...FQqk4Aod_RAAWQ
This tool is $26.00 but i havent tried it yet. Looks like it only deals with SRS code resets.
Old 01-17-2013, 01:59 PM   #5
mikeson
My Ride: 99 323I
Are you sure?
Because PA soft can clear SRS(airbag light)
Even you can reprogram SRS module (different vin number)
If you have PA soft and you couldn't clear it, then you don't know how to use it.
PA soft is best so far.
OEM xenon retrofit, Auto light/rain sensor DIY, OEM fog DIY,..........so many things DIY since 2000 :)
mikeson is offline   Reply With Quote
Old 01-17-2013, 02:03 PM   #6
trj
My Ride: 325Ci
It will clear the light as long as there is no problems with the airbag system and just needs to be reset.
I did on mine some weeks ago and now I have to it today again because I have to remove the air bag again to fix my door handle
Old 01-20-2013, 04:25 PM   #7
Jascha
My Ride: 330ci
That's puzzling... I purchased the version (uses the same PA Soft 1.4 software) from Resettoils (twice the cost) but cannot clear my airbag light despite the fact that SRS related functions all check and stay 'green'.
Any suggestions or thoughts (are there newer incremental updates to the software)...?
Thanks!
Jascha is offline   Reply With Quote
Old 01-20-2013, 05:38 PM   #8
shovelit
I got my software here. http://www.resettools.com/bmw_scanner_1.4.0
It is supposedly the new version 1.4.0.8
Scroll down to software then click the link.
Old 01-20-2013, 05:54 PM   #9
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Incorrect. It can and will clear SRS codes as long as there is no PHYSICAL fault.
Old 01-20-2013, 07:35 PM   #10
Tament
My Ride: 2001 330I
PA Soft reset my SRS light, not surE what you did wrong
Tament is offline   Reply With Quote
Old 01-20-2013, 07:44 PM   #11
floydlloyd85
My Ride: 2002 318 Ci coupe
Disconnect your battery before unplugging airbags.
floydlloyd85 is offline   Reply With Quote
Old 01-23-2013, 08:10 PM   #12
Jascha
My Ride: 330ci
The one I have is from the same supplier (version 1.4.0.6) -not especially responsive nor knowledgeable technical support. On occasion, this Scanner will not read ('not found') SRS module which is odd since a reboot of my PC will allow it to do so (even installed latest drivers). It shows old (yellow boxes) errors but light still is on... (?)
Old 01-23-2013, 09:06 PM   #13
shovelit
Strange. I've never had srs codes but my scanner reads srs fine.
Old 01-23-2013, 10:16 PM   #14
zhenkaaaM3
You sure? I tried to reset it. I can see it trying to remove the light, the SRS light blinks off and stays on. (I didnt have an airbag though)
Old 01-24-2013, 04:02 PM   #15
Jascha
My Ride: 330ci
In one of the minimalist English responses it was suggested that the SRS codes can be set inside the IKE Module under the 'Coding Data' sub-menu but I don't see how they relate...hopefully one of you, eagle eyed, young chaps can point to it (?)
Thanks for staying around!
Old 01-24-2013, 04:28 PM   #16
mikeson
My Ride: 99 323I
Actually, I saw some options that you can reprogram what equipments you have.
You can turn them on or off. If you turned off, then even you don't have an airbag, it won't light up.( I think but I haven't tried it yet but I reprogram some other options on SRS module(main computer))
Hope it helps.
Old 01-30-2013, 06:50 PM   #17
bwh3200
PA soft 1.4
Received the PA soft but i'm a little confused about the computer that i need to run the software with. I have read that i need 32 bit windows7. My computer is 64 bit, so i'm guessing that the PA soft won't work on my computer. Could someone clear this up for me please.
Old 01-30-2013, 08:04 PM   #18
zhenkaaaM3
I have pa soft with win 7 64bit. Theres a big thread on bimmerforums on how to make it work.
Eugene
